Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AUX will not start
Poulan PP4218AUX , 42cc with a 18" bar. It will not start. I am getting a spark & I also installed a new plug. I thought it was in the fuel supply but when I manually put a small amount of fuel in carb. & also tried in cylinder, it does not try to start.Is it possible that spark is not strong enough or does this sound like a fuel issue.
I have a 42 cc 14"bar will not start. poulan chain saw.
Posted on Feb 18, 2009
  • donnell norris Feb 18, 2009
    I just wont to know how to start my poulan chain saw. 42cc 14"bar
Where is the spark plug on a poulan pro 42cc
remove the top cover i think 4 screws the plug is under there
Sep 03, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulon pro 42cc saw that wont start. dont think its getting gas cuz i tried to flood it with the primer but no gas on the spark plug.
The primer will not flood it, all the primer does on these saws is pushes fuel through the carb. If this is a new saw, it needs a carb adjustment, a very common problem on poulan products these days. It's covered by the warranty at any of their service dealers (you can locate one on poulan's website).
How old is the gas you are using? If the mixture is more than 30 days old, make a new mix and try again.
Check for spark. Pull the boot off of the plug. Hold the boot near something metal and pull the starter. If you see a spark, you are good. If you don't, you may have a problem with the coil.
Aug 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cannot get the saw to start, even with starter fluid. Checked fuel line, compression, new fuel,....Yard sale item, new spark plug in saw. Don't know if it's right, but sparks when starting
I assume you have installed a new spark plug. Most common problem is the fuel pump diaphram in the carbuerator goes bad. Rebuild the carb in that case... about $20 for the kit... Last problems are the magneto coil or that the flywheel key has sheared causing timing to be off.
Aug 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 18 in poulan pro that want run. has new plug, air filter,gas filter
Check if is any "spark" at the spark plug.If not change the "coil" =spark plug cable and coil all are together.
Nov 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 260 42cc. Need a manual.
For parts manual
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Hi and low speed jets are both 1 1/2 turns open, fine tune from there.
Apr 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
783 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
