Question about Sony Playstation 3 (PS3) Console
PS3 Blu Ray Drive Not Reading Or Spinning Disc
Hi All,
Right im really good with the PS3 i have took it apart and sorted out my freezing problem, this was due to over heating, so i replaced the thermal compound on the CPU and GPU with Artic Silver 5.
Now the problem im faceing is the disc is not spinning and not detecting on the PS3 drive, Now i know i have not fryed the Laser, so has any1 got any sugguestions?
Thanks
Alex
  • 5 more comments
  • Alex Keen Feb 19, 2009
    Yea it worked fine before, apart from the freezing thats why i had to take it apart to put the thermal compound on the CPU and GPU.
    I did notice the disc does spin, and the laser does come on, but nothing else :S
  • Alex Keen Feb 22, 2009
    I have solved it now, i just took the drive apart, moved the laser along the slider then kept my finger on the eject button and it reset the drive :)
  • sergio200042 Mar 13, 2009
    The BD drive on my PS3 is not spinning the disc anymore, and as the warranty has expired, I can't fix it for free anymore. The Sony officials said that I have to pay 157 $ in order to get the problem fixed and hand over the old console (mine) and receive a "new" one (refurbished not new, most likely). As I don't want to spend my money for games, what can i do to fix the problem?
  • eddthekermit Mar 13, 2009
    my ps3 is not letting me play games or watch blueray dvd! all these code (800) keep comin up? wot should i do?
  • miguellatigo Apr 24, 2009
    I cleaned the lens on my blue ray player.. but when i put it back... The b-ray drive will take discs in but it wont spin. I verified the cables and everything. what should i do. It was working fine prior to the removal
  • VIDEOGAME REPAIR SERVICE
    Did it work before you took it apart?
    President:
  • 2,653 Answers
Check your cables. Try swapping lasers with a friend. Those are the first things I would try.
Posted on Feb 21, 2009
  • RescueTechLA
    RescueTechLA Feb 23, 2009
    Check out my common problem and easy repair guide here:
    http://rescuetechla.blogspot.com/
    It's FREE unlike the other guys trying to make a quick buck with their crappy guides.
    Please feel free to email me any other questions and don't forget to rate!
    Thanks!
    RescueTechLA
If your ps3 stops spinning discs its because its fallen or has been hit.
- 2 iron pins inside the bluray disc hold plastic mechanism
- if either of these pins are misplaced, ur bluray drive will NOT spin.
i just spent 5 hours figuring out how to solve this.
solution: open the bluray disc drive entirely, u need the bottom metal layer to be off the disc, then u will see the wide V-shaped metal arm that has 2 pins on it, facing upwards in the drive. One of these 2 pins needs to be placed back into the original position (this is a plastic whole in the exact shape of the metal pin).
PS: IF U TRY THIS YOURSELF BE CAREFULL
Posted on Jun 19, 2010
    New Friend:
Mines not the v shaped silver thing its accept the disc the lazors lighting up but the discs not spinning any ideas??
Posted on Apr 08, 2013
Hmmm can any1 conakt me on fb or send me step by step on how to fix dis prob i reely need my ps3 to wok
facebook username-rishabsayan
email id-rishabsayan@yahoo.com
Posted on Jan 25, 2011
Tip
PS3 stop reading disks? heres how to fix it.
So your shiney black pearl stopped reading discs huh? Now you are wondering if you can fix it because A)You are out of warranty and don't wanna pay almost 200 bucks to have it fixed or B) You are under warranty but don't wanna be without your PS3 for almost a month or longer .... Maybe you casn fix it on your own, if the problem is simple enough.
Sometimes the PS3 won't read discs simply because the lens is dirty, to find out if thats the case insert a game or blu-ray disc ... take careful note of the disc's 'label' as you put it in ... once it doesn't read after 10-15 seconds eject it ... if the disc's label hasn't moved your blu-ray drive's 'motor' is broken. Best bet is to send back to Sony and pay em. Or take the PS3 apart and try to replace the whole blu-ray drive.
If you remove the disc and notice it has moved your lens is probably dirty. This you 'can' fix yourself. First give the PS3 a GOOD cleaning. Vacuum it, blast it with a can of compressed air, vacuum again. Try disc.
Didn't work? Try a lens cleaner kit.
Didn't work? Time to get your hands dirty ... open the PS3 up (at your own risk) and clean the laser manually with pure alcohol and a q-tip. (video tutorials are on youtube.com)
Disc read errors are our main problem. It isn't some full blown epidemic but IS becoming worse by the day. My reasoning for this problem is simple: The PS3 is a dust MAGNET. I'm betting 90% of the disc read errors are cause by dust and dirt and pet hair getting in the machine and making the lens dirty or causing actual failure of the drive motor itself.
I love the PS3 and wish it didn't fail for anyone, especially this month with great titles almost here, but it happens. Happened to me on April 1st and I found out my blu-ray drive motor failed. A dirty lens I woulda fixed on my own. We really need a good blu-ray cleaner kit to come on the market in all major retail stores.
Peace PS3 fans.
on Jan 30, 2010 | Video Game Consoles & Games
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
On my ps3 80gb system, the disc never spins up. I don't have a problem replacing the part myself, but I don't know what part to order. can you help. Thanks! Mike
Hi there, the PS3 blu ray is a bit of a complex device. Basically the way it work is before the disc is even spun the laser reads and detects what kind of media is inserted into the PS3. As you are saying the disc is not spinning there are 2 possible causes for this.
1. The blu ray lens has gone and is unable to read blu ray discs, hence the disc does not spin as none is detected.
2. The actual motor that spins the disc has gone. This is a much more unlikely reason, the blu ray lens is a common problem on the PS3.
As a shot in the dark you could try a laser lens cleaner but make sure it is suitable for blu ray. If this does not work you are going to have to purchase a new blu ray drive. You can get them for around £70 on ebay but you need to make sure you get the right one. Check your PS3 model number and google it to find which drive you have.
Hope this helps and thank you for using FixYa
Sep 12, 2010 | Sony Playstation 3 (PS3) Console
The system is not reading any games
Hello there,
The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
  1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
  2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
  5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  8. Replace with new laser module, reverse your steps and reassemble the PS3.
Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    PS3 BluRay Drive Issue
    dont change the drive change the laser dhe drives are coded to each ps3 if that dosent work just change the hard drive whit the one that works
    Jan 06, 2010 | Sony Playstation 3 (PS3) Console
    PS3 80GB not spinning DISC
    the PS3 sony Blu-ray drive is very sensible..you should check the drive sensors first...
    Could be a defective motor that´s not spining the disc...
    would be very nice to test another blu-ray laser unit...connected with your blu-ray controller board...and you wil find if the logical blu-ray board is ok..or dead..So you must have a hardware to test and prove a second opinion !!!
    Good Luck !!!
    Sep 10, 2009 | Sony Playstation 3 (PS3) Console
    PS3 Won't Take Disc!
    Hi, I think it was me who had helped you before. I will be glad to help again. Ok, first you have to tear apart your PS3 (just like when you cleaned it). Now looking at the rollers and "dogs" make sure that they are closed and not open all the way like when a disc is in it. Look at the flap on the top too make sure it opens and closes freely. Next, PLEASE BE CAREFUL!! Plug your PS3 in and try to hit the eject button, if it is reset and ready for a disc it will beep twice when you hit the eject button without a disc in it. Place the top back on the he DVD drive and try to insert a disc. At this point it should take it. If not then try hitting the eject again. Once the PS3 resets and takes and ejects discs again, then you can put it back together.
    Aug 13, 2009 | Sony Playstation 3 (PS3) Console
    Blue ray will not play
    sometime it is because the reading lense in the PS3 is dirty you would have to take it apart and find a glass piece that looks like a circle wipe it off and you should be good to go
    Jul 14, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3 - discs not reading
    If the warranty is still intact, Sony can fix it. If not, open the ps3, open the blu-ray drive and clean the laser. If that doesnt work, replace the laser.
    Apr 24, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    23,075 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
