Look for a plastic screw cover at the top part of the table stand. You will have to use a plastic pry bar or plastic putty knife to unlock the inside holding clips. This procedure will have to be repeated when you remove all the screws from the rear panel to unlock the rear plastic casing from the front panel casing. Be careful not to apply to much pressure or you may break the plastic locks that hold together the case. Hope this helps you with your problem.
LCD Dell E228WFP It shuts off the picture every few minutes. If you turn the monitor off and wait a...
(More)
LCD Dell E228WFP It shuts off the picture every few minutes. If you turn the monitor off and wait a few minutes it will come back on and stay on ,but it just keeps repeating the shutting off. What do I do.
19 flat screen -amber light stuck - self check sceen comes up but rarely goes to green. Happens...
(More)
19 flat screen -amber light stuck - self check sceen comes up but rarely goes to green. Happens monthly. Unplug everything then back works sometimes. Not sure if my grandson hits a button, any suggestions?
the whole time my computer is starting up my monitor clicks on and off untill the computer is...
(More)
the whole time my computer is starting up my monitor clicks on and off untill the computer is completely loaded help me please i am desprate lol
After sitting idle for a period of time, the monitor (Maginnovision)will turn black after I hit a...
(More)
After sitting idle for a period of time, the monitor (Maginnovision)will turn black after I hit a key to get the desktop back. I then have to do a hard shutdown and reboot. Sometimes this happens when I go to start up the computer in the morning. Any suggestions? Thanks.
