Question about Sony VAIO RA710G (VGCRA710GWITH17LCDDISPLAY) PC Desktop
Why.does.my.spacebar.not.work? i.removed.sticking.spacebar.to.clean.gunk.underneath.......after.replacing.it.does does.notwork.
  • skyhawk2235 Feb 21, 2009
    the pad was still at bottom of tube.....i dropped two drops of electric pre-shave on it .....(alcohol with a slight amount of lube)...after a day or two it dried out and is working as good as new now ......thanks,for your suggestions.
    Scholar:
  • 164 Answers
The pad has slipped.. open KB and reset.
Posted on Feb 19, 2009
3 Suggested Answers
  • 7 Answers
SOURCE: spacebar.quit.working.
Try to reseat the space bar again.
SOURCE: media.center.keyboard.spacebar.does.not.work.after.cleaning
i have already posted the solution to my problem.....but i will tell you in more specifics what transpired.........after removing my spacebar.....i used electric pre-shave (an alcohol based solutions with a slight amount of lubrication).......with a few drops of that and a q-tip i cleaned the black tarry mass that had accumulated underneath the space bar most likely from spilled pop,coffee,pancake syrup,cat hairs,and only god knows what else...........after replacing it it worked fine mechanically and physically but did not work on the screen......after a day or two it started working .....i guess the alcohol needed to dry out .....i did put two drops down the tube that had a pad at the bottom (contacts underneath it ).........everything working better than new now .......thanks for being here to help.........
Posted on Feb 21, 2009
Is it possible to adjust the sensitivity of the keyboard? My spacebar doesn't work unless I press it uber-hard!
no there is not a sensitivity setting for the spacebars, however, some people have eaten or trimmed their fingernails and so on by their computers and in turn have gunk stuck up underneith the keys.
So check to make sure something has not landed up underneith it and clean it out if it has.
and make sure the keyboard is seated correctly. (if other keys dont work or don't work well this is a sign that the keyboard connectors are not seated correctly, but if all other keys work fine it is not a seating issiue and your cables are connected just fine.) If under warranty call the HP techs first!
otherwise http://h10032.www1.hp.com/ctg/Manual/c01918142.pdf
Page 70 will get you to the techs maual on keyboard removal, cleaning and so on. a dry toothbrush and a vacume will go a long way though....
Apr 30, 2011 | HP Pavilion dv7-1130us laptop
Myspacebarisnotworking
Greetings,
You may have some small item underneath the spacebar. The spacebar will "pop up" if you use a screwdriver or something to pry it up from the keyboard. Insert it near the B on the top side of the spacebar and pry up towards you. Clean out from underneath and reattach it.
Apr 16, 2011 | HP D8597A Keyboard
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Spacebar.quit.working.
Feb 18, 2009 | Sony VAIO RA710G...
Media.center.keyboard.spacebar.does.not.work.after.cleaning
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Feb 18, 2009 | Logitech 967437-0403 Keyboard
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Open Questions:
See all Sony VAIO RA710G (VGCRA710GWITH17LCDDISPLAY) PC Questions
Sony VAIO RA710G (VGCRA710GWITH17LCDDISPLAY) PC Desktop Logo
231 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
