Question about Homedics PS-200 Iron with Auto Shut-off
The ps 300 will not heat although the on light is on
Steamer only used once and the on light is on but no heat or steam . The body of the unit gets warm but that is all. I have held checked all of the parts and they seem to be ok. I have the wand at full length and yet nothing. Help
I bought one of these units at a Salvation Army Store still in the box brand new. I experienced the same problems (power was lit, but the breaker would trip and turn unit off). I opened the unit up and since I have knowledge of circuits, I bypassed the breaker (trips when it reaches a predetermined temp). I did however add a CRUCIAL electrical component that makes this possible an keeps your house from burning down - a added a simple dial thermostat (like one from a single electric plug-in coil stove top). Bottom line, I took on this project moreless for fun and I would NOT RECOMMEND anyone try this unless you have some knowledge about electrical circuits.
Posted on Aug 26, 2009
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
PS-200 Iron with Auto Shut-off: Can you really fix problems with a steamer? Is ...
The thermostat is the problem, I used aew3656's solution posted elsewhere in FixYa, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW don't forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 16, 2010 | Homedics PS-200 Iron with Auto Shut-off
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
Home touch 300 no steam coming out
Hold the hose straight up fully extended for several seconds--it says to do this in the manual--and works great
Nov 15, 2008 | Homedics PS-200 Iron with Auto Shut-off
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Homedics PS-200 Iron with Auto Shut-off Logo
403 people viewed this question
Top Homedics Irons Experts
Are you a Homedics Iron Expert? Answer questions, earn points and help others
