Question about Toshiba Satellite 1130-S155 Notebook
When i plug in a/c adapter to toshiba laptop it sparks at
Connector and still doesn't come on, i purchased new battery and adapter and still same problem.
    President:
  • 2,992 Answers
A couple of possibilities:
1) The power jack on the main board needs to be resoldered. Sometimes the connections break at the circuit board because of power plug flexing. This is not a difficult repair, but it means taking the main board out so you can reach the solder side (bottom) of the board. In some cases the main board can be damaged because of heating and arcing at the bad connections, and occasionally the damage is serious enough that the board needs to be replaced.
2) The main board in the computer has failed. Almost all of the electronics in a laptop is on one big circuit board, and when it fails, a "no boot" condition is a very common result.
If you don't feel comfortable taking out all the screws and covers to get the board out to try your own repair, I would suggest getting an estimate from a servicer. The shop I used to work for charged a little under $100 to repair the board if it was bad connections.
Posted on Feb 18, 2009
When i plug the charger in the orange battery light comes on and the computer turns off
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Sep 29, 2012 | Toshiba Satellite P200D-11R Laptop AC...
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
My battery doesn't recharge laptop when laptop is plugged in . What to do and at what approximate cost if new battery needed?
Hi there! There are two possible causes of the problem - it's either your battery or your AC Adapter. To diagnose whether or not it is your AC Adapter, test it this way. Does your laptop function with the power cord plugged in and the battery out? If this is the case, your AC adapter is fine and your battery is done. To replace the battery, expect somewhere between $75-$175. Here is a link to the cheapest battery site I've found so far - I use it for work all the time. http://www.batterydepot.com/mfg/TOSHIBA/LAPTOP-BATTERIES
If your laptop doesn't work with just the AC adapter plugged in, then that is your problem! AC Adapters are cheaper than the batteries. They can be purchased here for around $50: http://www.buylaptopadapter.com/toshiba-adapters.html
Make sure you match the model number on the bottom of your laptop perfectly with the model number of the battery or AC Adapter! Good luck! Alex
Apr 30, 2011 | Toshiba Satellite PSPA0U01S006 Notebook
My tosiba satelite a75-5209 not switch on
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 06, 2011 | Toshiba Satellite A75-S209 Notebook
I goofed. I have a Toshiba Satellite A105-S206, and I will make this as brief as I can. I have had a string of super cheap power supplies that I have been using. The most recent one stopped...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Toshiba Computers & Internet
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
When i plug in a/c power adapter to my toshiba laptop it sparks
Sounds like your ac port is broken. If you can not run it off ac or battery this would be why. There is no current flowing to the motherboard. Is the ACjack loose?. If so you need your ac jack repair. A local repair shop can do this. Unless the system is still in warranty. You should be able to call support and tell them that your notebook is not working due to a malfunction ac port.
I hope this helps you.
Feb 18, 2009 | Toshiba Satellite 1135-S155 Notebook
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Jul 30, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
How handy are you with a digital multimeter? If the laptop is still disassembled, find the solder connections on the motherboard where the mini power cable enters the board from the jack. Plug the AC adapter in. Check to make sure you have the proper DC voltage at those points (should be about 19V, although the AC adapter should say what it's DC output is).
If you don't get any DC voltage (or too low), check the DC plug of the AC adapter. The inside of the plug should be + and the outside should be -. If you are getting voltage there, but not the motherboard, chances are it's the jack or the mini power cable on the motherboard. These can be replaced, it just depends on how confident you are about doing it yourself :).
Mar 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite 1130-S155 Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
