Question about Philips 55PP9352 55" Projection Television
Red power light on. chirping beeping sound
My magnavox dptv310/philips 55pp9352-17 is having problems. power light is red and thier is a chirping/beeping sound. i researched and i was told to order a kit that has two new chips and 12 resistors in it. i just recieved it and soldered everything in. when i powered up it still does the same thing. any ideas what else it might me. thanks for your help.
mike
    Genius:
  • 1,139 Answers
Hello sedekim,
First check you connections to the circuit board some times the connections go bad from the deflection board to the signal board, if this is not the case the bottom advice may be of help.
That problem indicates that the Horizontal Output Transistor (HOT)is beginning to malfunction. I would suggest that if you have a background in electronics that you do the following:
1) unplug and open the back of the set
2) look for the HOT and locate the Collector, Base and Emitter of the transistor and using your multimeter set to read resistance measure from the collector to the ground, it should read high almost infinite, red from base to ground it should read low and from emitter to ground it should read low.
3) if the HOT when read from the collector to ground reads low then you can bet that the HOT has a short circuit from collector to ground, and will have to be replaced.
4) In addition I would also perform a ring test on the Integrated High Voltage Transformer (IHVT).
This will tell you if the IHVT has suffered any damage from the HOT malfunctioning. You may end up having to replace both of the components.
If you do not have a background in electronics I would suggest that you take the TV to your local TV repair facility.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 20, 2009
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
Makes a chirping sound.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
May 25, 2010 | Philips Magnavox 51MP392H Rear Projection...
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Tv show nothing
If the set is making a chirping sound its usually the Flyback and or the HOT transistor which are both located on the LSB board
Mar 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Same problem as JoshJOhnson posted on Jan 21 08
What is the chassis number on that set. We have a complete Chassis that we are parting out HDTV magnavox with the DPTV 305 through 345 which should be the same chassis as your set. We sell used parts this is a working tv with a cracked blue tube were selling it as a complete chassis or individual boards on our site. Let me know if you may be interested. Chirping comes from the deflection circuits possibly flyback related.
Mar 05, 2008 | Philips 60PP9202 60" Rear Projection...
No sound no pic!
That is the DPTV310 chassis I believe the problem could be in the power supply input board or the large signal board. I have a source to locate those boards used if you would like me to post it. They sell parts cheap and all parts are in good working order. I have used their parts many times.
Feb 23, 2008 | Philips 55PP9352 55" Projection Television
Philips 55PP9352 55" Projection Television Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
