Question about Kyocera Mita FS-C5020N Led Printer
Receieve ?Call Service? referencing the # F030:0014903 on Kyocera FS-C5020N.
  • 622 Answers
Main controller board is bad
Posted on Dec 24, 2009
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Black streaks on my output on printer fs-c5020n
chec below things
1. clean the drum unit
2. check the charge unit also
3. clean inside of the printer ...
4. check fuser unit heat roller any black streak is there...........
Nov 07, 2009 | Laser FS-C5020N Led Printer
Can not print pdf double-sided on Kyocera FS C5020N
surprised you actually got doublesided... ok... in a situation like yours... I would update to the latest adobe reader... that has been known to give you issues with printing.... and if it continues call kyocera support... this sounds like an issue they would want to work on...
Oct 05, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
FS-C5020N just put new toner in, color not print
your best bet with this one.. is to call kyocera support... they might give you a simple answer.. where as a tech will charge you an arm and a leg...
Apr 23, 2009 | Kyocera Mita FS-C5020N Led Printer
Kyocera fs-1920 (call service 6400:0040085) help!
the printer will require a need new fuser unit or a new power supply.
let me know if you need more help
Oct 24, 2008 | Kyocera Mita FS-1920 Laser Printer
I have a Kyocera c5020n with an occasional error "call service 7001: 0020988. It does clear if I power off/on.
This what it means (7001 is the error code: 0020988 is the page count) -
Toner motor 4 overcurrent detection
error (black toner)
• The engine controller PWB (KP-1054)
detected the overcurrent of toner
motor 4.
Defective toner
motor 4.
Jun 15, 2008 | Kyocera Office Equipment & Supplies
KYOCERA FS C5020N PRINTER QUEUE
remove from driver from control pannal>add remove program>
uninstall your printer driver & reinstall it i m shore its help u
Feb 21, 2008 | HP PSC 1410v All-in-One Printer
Kyocera Mita FS-C5020N Led Printer Logo
422 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
