Question about Motorola Mobility Z9 Cellular Phone
I would like to disassemble Motorola Z9 phone. Any ideas how to do it?
  • 4 more comments
  • chd1987 Feb 18, 2009
    I have a Z9 phone and want to replace the keypad. Need help with disassembly.
    I have already removed the back cover, battery and 4 screws on the back side. What is the next step?
    Can't find on Google.
    I have the special screw driver already and unscrewed 4 screws on the back side. What is the next step?
    I have two units and both of them have different issues. i want assemble good parts into one and make it workable.
    The service manual attached is for V9 and not Z9.
  • 13,433 Answers
  1. Turn the phone off
  2. Push the battery cover up, towards the top of the phone to release it
  3. lift up and remove the battery cover
  4. Pull the tab on the label near the hinge, then remove the battery from the
    phone.
  5. Remove the sim card and the sd card
  6. There are two screws you need to remove I would like to disassemble Motorola Z9 phone. Any - cfb19c8.jpg
  7. Using a Torx driver with a T-5 bit, remove the screws at each side of the phone.
    Retain the screws for reassembly.
  8. Turn the phone over so the keypad is facing upward.
  9. Use the disassembly tool to remove the bumper pad below the keypad
  10. 7553166.jpgThen remove the two screws under.
  11. turn the phone over so you see the back Release the first housing latch by inserting the flat edge of the plastic
    disassembly tool at an angle through the slot on the rear housing then push
  12. The rest of the service manual is available at
  13. http://www.4shared.com/file/67373684/bf0a868f/Service_Manual_RAZR_V9.html
Posted on Feb 18, 2009
  • Ekse Feb 18, 2009
    Its all in the service manual, I sent a link for you.
  • 23 Answers
I scoured the internets looking for a guide to get this bugger apart, but got bored and started poking around with a screwdriver and got it apart (with some very careful and brave prying)
I don't have a camera but here's a summary of how I did it:
1. Remove the battery cover and the battery. Always remove the battery.
2. Get a small screwdriver and pry off the cover on top that is over the camera lens and flash.
3. Remove all visible screws from the back.
4. The black piece needs to come off now, get a screwdriver or pry tool and get under it and carefully pry it up.
5. Now you have access to the board, there are 3 connectors underneath it that you just need to pop off.
6. With the board out of the way, you can see 4 more screws. Remove those and you will be able to separate the two halves (there is some glue holding it together I thought there was something else attaching it but it should come right apart)
7. Now you can take out the 6 screws holding the LCD together.
8. Take off the back of the LCD and now you can get to the screen! I haven't actually removed the screen because I was still getting a display, but it was discolored and yellow. I tried re-seating all the cables and the display works great now!
Hope this helps, sorry I can't be more detailed about the LCD but I already put mine back together and stripped a screw -_- its working now so I can't complain much.
Posted on Jul 18, 2009
  • monadity Sep 07, 2010
    Thanks!!
    1) SIM card needs to be out so one of the screws in 3 is not missed.
    2) There are 4 connectors in 5 if you include the single wire (coax) connector that looks like a terminal, but is a connector near the bottom of the board. It will unplug
  • 19,396 Answers
You remove the external covers then you have a set of screwsa to remove, I think I have a movie on this.
    Guru:
  • 832 Answers
Hello! thanks for using Fixya.com
you may follow the instruction below:
First, turn off your phone:
  1. Push the battery cover up, towards the top of the phone to release it
  2. lift up and remove the battery cover
  3. Pull the tab on the label near the hinge, then remove the battery from the
    phone.
  4. Remove the sim card and the sd card
  5. There are two screws you need to remove
  6. Using a Torx driver with a T-5 bit, remove the screws at each side of the phone.
  7. Turn the phone over so the keypad is facing upward.
  8. Use the disassembly tool to remove the bumper pad below the keypad
  9. Then remove the two screws under.
  10. turn the phone over so you see the back Release the first housing latch by inserting the flat edge of the plastic
    away to disengage the two front snaps.
Good luck!!! Cheers!
    Brigadier General:
  • 3,614 Answers
Ok.. wait here
  • micromaster
    micromaster Feb 18, 2009
    if you were just changing covers:
    No Disassembly of your Motorola Z9 cell phone and No Tools required for installation.
    Top Expert:
  • 77,169 Answers
On the outside of the phone there will be small rubber plugs, under those will be tiny torx security screws, there will also be screws under the battery cover, to get the special screw driver for the tiny torx screws go on ebay and buy a kit, real cheap, about $6
  • 3,051 Answers
Hi there
google has a site that deals with the dissasembly of all motorola phones just use the (dissambly of a motorola z9 phone ) search
  • 15,935 Answers
You definatly don't want to attempt without the disassembly tool.
It is a levered plastic tool that separates the 2 halves of the phone without damaging the circuitboard.
Without this tool, disassembly is not advised.
Your local phone tech can halve them for ou for a nominal fee.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • 544 Answers
Hi thank you for choosing Fixya.com..
disassemble you mobile specially with a sensitive unit just like you will caused a big problem may caused of damage or loosen some spart part..
please i strongly suggest to you that take your mobile to specialist technician so that we can prevent problem may occur of ruining your unit..
hope you will follow my suggestion it is for your own good..
  • Mark Milan silaran
    Mark Milan silaran Feb 18, 2009
    hello their again sir,,
    please go to youtube and type tis to search tab..Motorola RIZR Z6c Review
    their you can find direction how can you change your housing..
    hope this one will help you...
    thank you..
    hello their again sir,,,
    plese go to youtube and put the search tab..disassemble Motorola Z9 phone
    their you can watch how to diss assemble your unit perfectly..
    follow very carefully.
    hope it will help you and can change my rate..
    thank you...
    Genius:
  • 1,550 Answers
First off all remove battery . Then remove sets of screws present in it . Then be careful in removing the board and its connection with the screen . You need to be careful doing this . If you a have service manual with you it will be helpful .
Unlock motorola z9
Using codes you can unlock your mobile because its safe for your mobile.......
Get the unlock code for your motorola Z9 model mobile here Simpleunlocking.com , it gives the easy instructions to get your mobile as unlocked........
Dec 15, 2011 | Motorola Mobility Z9 Cellular Phone
I need an unlock code / subsidary password for motorola z9
Get the unlocking code from your network provider or you may get it from online providers like Theunlockspot.com .They will help you to unlock your mobile easily..
Apr 28, 2011 | Motorola Mobility Z9 Cellular Phone
I only have had my Motorola Z9 for two weeks and it just turned off of me the other day, when it had a full charge. I tried taking out the battery and putting it back in and keeping it plugged into the...
try taking the battery out plugging in the phone to the charger see if it turns on if it does then plug in the battery . let me know if that worked i have other ideas but thats a start
Mar 26, 2011 | Motorola Mobility Z9 Cellular Phone
Replacing screen in Motorola Z9
its better you give it to a repair shop u need to the expertised tools with u inorder to chane the screen.
Jul 14, 2009 | Motorola Mobility Z9 Cellular Phone
Setup Speed Dial on Motorola Z9
Go to entry in address book, select Options > Add to Speed Dial then Select Position.
Mar 12, 2009 | Motorola Mobility Z9 Cellular Phone
Motorola Mobility Z9 Cellular Phone Logo
2,865 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
