Question about Garden
Adjust carburetor gas and air intake on craftsman chainsaw
How many times do you turn the two set screws on a Craftsman chainsaw model 358.350360 carburetor?
ex: one on the left - put screw all the way in and back off 1 1/2 turns
one on the right - put screw all the way in and back off 2 turns
  • 2,176 Answers
There is too much information to relay so I would suggest you go to Searspartsdirect.com and type in your saw number and on the right side there is an area for a manual. You will need to use your email addy and select a password for this but it is free. You can view or download the manual and the area you need is on page 15. Let me know if this won't work and I will copy and retype info requested.
Posted on Feb 18, 2009
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Chainsaw stalls and won't restart
make sure you have the right spark plug and gap is right on for that model.
Apr 13, 2014 | Craftsman Garden
Craftsman chainsaw chainsaw troubleshooting .....mine runs with choke on but speeds up and cuts off when i take choke off?
Denise,
Check to see if the boot between the carbureator and the engine has a crack in it, if it is cracked air will leak in causing a lean mixture and hard starting. Also will not run unless the choke is on.
Mar 30, 2014 | Craftsman Garden
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What is the factory settings on a craftsman 2.3 chainsaw and to adjust carburetor
tighten the two air screws to just tight then slacken them to one and a half turns start the engine and adjust the low screw until tick over then open the throttle to full and adjust the high screw if it cuts out take the high screw to one turn and try that then adjust from there
Can't start chainsaw
Walter:
gently run the fuel and air mixture screws on the carburetor all the way closed (clockwise).then turn them out one and a quarter turns each. That setting should allow the saw to start if you are getting fuel to the carburetor. Once the saw starts, make fine adjustments to the fuel/air mixture screws until the saw runs to your satisfaction.
Jul 13, 2013 | Craftsman sears 18" Chain Saw Chain (...
Saw will lnot start----needs gas intake adjustment
Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that will allow the engine to start and run. Let the engine warm up, then pull the throttle full on--turn H screw CW until the engine speeds up somewhat. Proper adjustment is when the engine is 4-stroking unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 14, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman chainsaw runs, but bogs down and/or quits when throttled up.
Try turning the "L" needle 1/8 CCW If no better try 3/16 CW. The "L" is primarily smoothness at idle and acceleration.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 16, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
10 year old craftsman chain saw14 or 16 inch sears craftsman
Duplicate Post
There is usually a sticker with a craftsman Model Number on it, often "358.Something". That number can be used to find an IPL and if you are lucky an OM here: Sears PartsDirect http://www.searspartsdirect.com/partsdirect/index.action Start at 1.5 CCW from lightly seated then tune for performance like this:
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Duplicate Answer
Feb 19, 2010 | Homelite Garden
Poulan 295 farm boss chainsaw
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
2,141 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
