Question about Makita HP1500- Factory-Reconditioned 5 Amp 9/16" Hammer Drill
Drill motor runs at full speed as soon as plugged in
Just began this issue recently. I may have overheated this during a concrete drilling session.
The trigger does not control the motor speed. As soon as the cord is plugged in the motor starts and goes to full speed. The trigger has no affect and the little button to lock the trigger on is in the 'off' position.
Is this a brush issue?
The unit was purchased new about 11 years ago and sees household use.
  • Anonymous Feb 19, 2009
    I took the outer case off and the switch had two little screws that looked like they held it together, but I couldn't get the switch apart? I think I would need to in order to replace it. I'll look again and check the e-parts schematics.
    I took the case apart and the switch looks like it is in another case. I couldn't get this smaller case apart. I'll look again and check the e-parts schematics.
  • 2,176 Answers
I would have to think that it is more of a switch issue than brushes. If you remove one half of the handle do you see that the switch is burnt? But either way the current has to run thru it and if it runs when plugged in the contacts have welded shut to complete the circuit would be me guess. You can get a switch almost anywhere or go to Makitausa.com and order it direct. Let me know what happens please.
Posted on Feb 18, 2009
I own a DC988 XRP drill. I recently used it for drilling some holes. While drilling I heard a pop and now the drill only spins at a slow speed. Any advice as to what component needs replacing? Brushe
That drill had several speed options, do you have it on high?
Brushes are usually a power/torque issue and wouldn't effect speed unless they were really bad
Nov 29, 2014 | Drills
Hi. I was drilling a few holes in concrete with my TE 56 HILTI and the drill bit become jammed. it began to smoke so i put a new set of brushes in it and still the same spins slow and smokes, any...
It sound like is has overheated or a bearing has seized. Take it to hilti. www.hilti.co.uk for nearest dealer. They will collect for a price.
Dec 11, 2012 | Drills
I have a Bosch 1/2"
Sounds as though you are on the right track. I would take it apart, and see if the trigger could have some dirt or other material causing it to stick, or is it worn to the point that it needs to be replaced. Good luck!
May 30, 2017 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Cant seem to drill into concrete with tapcon bit in 18V P205. What settings and speed do I use?
You should be able to drill at a low speed. Maybe 100-200 rpm. I assume the bit is sharp. I have run into an ocassional new bit that is bad. If it suddenly stops drilling you may have hit a rock. Crack the rock with a center punch then continue drilling.
Apr 01, 2011 | Ryobi 18v 38" One+ Cordless Drill P205 18...
Generator starts with and runs great, but theres no current on my toy hauler
Johnny,
If generators are not used regularly, they need the their magnetic field to be charged (or flashed). This can be done by plugging an electric motor into the socket while the generator is running and spin the motor by hand. The hand-spun motor will push some electric current back into the generator and magnetize it enough to start it.
Look in the manual. There is likely something about field flashing the magnetic field2.gif. The easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Nov 16, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Drill stopped work ing when hot. One drill we bought stopped after 10 6mm holes. The others work when you pull the trigger and then sometime they don't.
Sounds like a burned out motor.
Sometimes you can replace the brushes and make them work again.
When operating that drill, make sure that you are not overheating the motor.
Depending on the material that you are drilling, you may need to use the drill on a slower speed in order to not overheat the motor.
Another way is to have more than one drill, and switch to a cool one as soon as you notice heat on the in-use drill.
If your drill is battery powered, stop using the drill and change the battery as soon as the battery dies enough to slow the speed of the drill.
Operating the drill under reduced power is very hard on the motor for several reasons.
Oct 28, 2009 | Milwaukee Tool Drills
Drill stop working after drilling hole in concrete. I can see smoke coming from drill. Now both forward and reverse does not work any more. Is the drill motor burnt out? Or is there a fuse that I can...
With the DeWalt cordless drills, the weak link is that the leads tend to burn (melt) off at the motor brushes when the drill is overloaded. It's happened to mine now about 3-4 times, so much so I've had to replace the wires after they got too short to put a new terminal back on them!
The only other issue is that the trigger mechanism could have failed due to the hevy load of drilling in concrete. But before you spend the bucks on that, you can easily check to see if it's the wiring or the trigger assembly.
Before you take anything apart, make sure the top speed selector is at #1, and the torque setting set to the lowest setting. (makes it easier to remember if you have the speed selector come out of the drill body)
Now lay the drill on it's side and with the battery out of the tool, remove all the screws that hold the two halves together. Take off the top half and look at the back end of the tool to see if the wires going to the motor are in good condition and not burned off the motor brush tabs. If they are, you can either resolder them or recrimp them (DeWalt used different methods for different models) with a new .25 female terminal (any auto or hardware store will have them)
You can give the repair a quick check (IF you are careful) by putting in the battery into the lower drill body and holding the drill motor, gently squeeze the trigger and see if the tool runs. If so, you've fixed it and can put the drill back together.
If the wires are good, then it's the trigger assembly and you'll have to get one from either a DeWalt Authorized service center or distributor that carries repair parts, as these are sealed units and can't be fixed (I've tried). There are some available online too, if you wish to do the replacement yourself, which is a straight forward unplug and plug operation, now that the tool is apart.
Reassemble, making sure the speed selector is in the slots on the tool body and everything else lines up correctly. Install the screws and you're back in business.
Hope you find this very helpful and best regards!
Aug 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Makita HP1500- Factory-Reconditioned 5 Amp 9/16" Hammer Drill Logo
168 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
