Question about Acer TravelMate 2300 Notebook
Display flickers on acer travelmate 2410
Acer travelmate 2410 display flickers-- was dim and barely visable, replaced inverter last week as recommended by acer support. they told me if any further video problems, I would have to replace screen assembly because the screen cable assembly would be bad and was made into screen. i just need to know if the cable is available seperately and how to test further.I already hooked pc to external monitor and ran a diagnostic cd, the mobo tested good and the screen was clear and did not cause any problems.
call me 601-341-8594
    Novelist:
  • 137 Answers
So, did the new inverter fix the problem? and, when you were replacing the inverter, did you get to peek at the screen? ok ok, I'll make it easier than that. take your model number and search for "Acer 2410 LCD" on eBay, there are a lot of screens and none of them show a video cable that is glued or soldered to the screen. there are, in fact, a few video cables there as well, so my guess is that they are flat out lying to because 1) to get you to pay too much for repairs 2) because the person at tech support has no idea 3) they are sold together according to their parts list or 4) they really DO go together. My guess is that what they are talking about is a completely new LCD panel INSIDE a lid case with the hinges and bezel and all that. So SURE it's going to look like the cable is included, but if you just pop the back off the lid, it's probably about 10 minutes of work to replace the LCD without replacing the cable. I have to provide 2 caveats to this:
1) Acer is NOTORIOUS for glue. they love the stuff and may well have glued everything together inside the screen case.
2) I have no real experience with this specific model so I'm not sure.
It's just that every other screen ever is pretty much made of the same parts: an LCD screen with a backlight cable and a video input socket, an inverter if it's in the screen, mic, video camera, light, etc if they are in the screen, frame, back of case, and a video cable that goes from the video socket out to the mobo.
IS the display light flickering or the display image? that's important too. Good luck. it's my guess that it's either a bad connection a bad CCFL or was a bad inverter. the cables may have gotten pinched and that could be it too.
Posted on Feb 18, 2009
Backlight very low making screen dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 29, 2009 | Acer TravelMate 4200 Notebook
Screen is dim barely can see desktop in background
Usually this is a problem with the backlight, or inverter. Most of the time the inverter is the problem which is a pretty cheap fix. If its the backlight, then you will have to replace the lcd, which is much more expensive.
Normally this is caused by the power inverter for the lcd2.gif. It is a small circuit board right below the lcd, that powers the backlight. If you take off the front bezel of the laptop you should be able to see it, it will have a 2 wire power cord coming out the one end, and another plug in2.gif on the other end with several wires.
Check ebay for a replacment but make sure you get an identical model as the one you have, as they are very specific to each laptop. The inverter will have the part number written on it.
Sep 11, 2009 | Acer 22" X223w LCD Monitor
A three inch verticl faded portion of screen
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Acer TravelMate 2300 Notebook
Adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Acer Aspire 5630 Notebook
Acer travelmate 2410 broken screen
Hi
2 THINGS,one it could be the lcd cable has come loose behind the lid,
or the inverter is faulty.if your happy to take lid off an reseat the cable.
two.the screen cable maybe loose at the motherboard end.unplug power supply,remove battery,and unscrew keyboard,pull off cable an reseat the lcd cable.
i hope this may help
May 19, 2009 | Acer TravelMate 2300 Notebook
My acer aspire 4320 have no light in the display
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Picture flickering with dim display.
Apr 26, 2009 | Acer TravelMate 4320 Notebook
The display has dimmed, and looks washed out (faded)
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 05, 2009 | Toshiba Satellite 4010CDS Notebook
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Jan 22, 2009 | Acer TravelMate 4100 Notebook
ACER travelmate 529 dim display
you need an inverter board. we can supply you with it if you'd like. let me know if you need more help.
90% of it's the inverter board, the other 10 could be a bad fl tube in the lcd itself.
Jun 16, 2008 | Acer TravelMate 529ATX Notebook
Computers & Internet Logo
173 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
