Question about HP Office Equipment & Supplies
I have HP all in one. The feed for fax stopped working. how do I fix it.?
  • 27 Answers
Try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Posted on Mar 05, 2009
FAX MACHINE 2140, THE PAPER FEED WILL NOT CATCH CAN THIS BE FIXED
it can.there is,inside paper feed section, some rubbers(one or two) try to clean them with alcohol and cloth,gently!
Feb 26, 2015 | HP Fax 2140 - fax / copier B/W
How can I fix paper feed problems for hp 2140 fax
Clean the roller and separation pad in the paper pick up area. Use a rag w/ soap(just a little w/ hot water or use SANDED PAPER and gently do circular move to GIVETHE RUBBERA STRONGGER GRIP or replace it.
Jun 25, 2014 | HEWLETT-PACKARD HP 2140 Fax
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I have an hp laserjet 3050 fax machine. When I go to fax several documents at one time, the fax grabs the whole stack and sucks them through. How can I fix this problem?
The first step is to insure that the top cover on the Automatic Document Feeder is closing properly. If it is not, the pages may multiple feed. If that is fine, then there is a pad that separates one page from the next in the ADF assembly. It wears out over time and begins to let the pages multiple feed. The part is normally replaced with the feed roller in the ADF at the same time. These are usually changed by a technician. The part #'s are RM1-0890 for the pad and RM1-0885 for the roller, you should be able to order them online.
Hope this helps!
May 15, 2008 | HP Office Equipment & Supplies
Always feeds a second sheet
You may need to repalce your pick-up roller and your stop roller
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper feed jam
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
good luck
Dec 12, 2006 | HP 1010 Plain Paper Thermal Fax
Seeker5211
Seeker5211
