Question about Toshiba Satellite A105 Notebook
LAN PROBLEM i cant get internet connection? pls help me
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    please could you clarify if its a wireless driver you need or the LAN itself?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Sounds like you are connected to a wired LAN. You need to make sure your network card is getting a signal. Check in control panel and see if you have a network connection. If you do have connection. You may just just need to reset your Internet settings to default and restart the computer. You also can do a repair of your network connection and see if this helps. Really need to know what type of network your tying to connect. It it a business or home Internet?
Posted on Feb 18, 2009
Help Please! I had to reset the hard drive to factory settings on an Advent Roma 1000 laptop. It can locate & connect to the router but cannot access the internet. It says 'no internet access'
the drivers for lan and wireless
Realtek RTL8168D/8111D Gigabit
Realtek RTL8187SE Wireless LAN
pls download the drivers here
http://www.adventcomputers.co.uk/product-download-select/102
pls try to configure ip address for your router and
also if you can login to router pls check the router settings for internet
Oct 28, 2017 | Advance Computers & Internet
No internet access but connected - windows 8 pro 32bit
DHCP controls this process. What are the DHCP settings?
Mar 17, 2017 | Computers & Internet
Cant get on the internet
Heelo,
we need more information then this.
What make and model laptop, operating system etc.
How are you wanting to connect (wired or wireless) which make and model modem you have and they type of internet connection (ADSL, cable etc)..
Feb 17, 2011 | Computers & Internet
Need help connecting my computer to the internet?
Have you downloaded the CD provided by your ISP in computer. If not do so and then try new internet connection.
Yellow ball going sideways that your computer is trying to search for internet connection.
Nov 16, 2009 | Microsoft Windows XP Home Edition
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Oct 13, 2009 | Cisco 857 Router (CISCO857K9)
Cant get net connection
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Dell-Vostro-200-LAN-Driver.shtml
May 31, 2009 | Dell Vostro 200 PC Desktop
Yahoo messenger 81003005 error
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Nov 27, 2008 | Yahoo Messenger
Pal i need lan driver for my lap top
log on to
http://tinyurl.com/3aomff
either enter your system's service tag
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
or
choose your system model
confirm your selection
next page will give you an option which says drivers and download
be sure the operating system you are using
download network driver then install it.
if stilll you are not sure provide me the service tag i'll give you the right link
Jun 06, 2008 | Dell Inspiron 1150 Notebook
Cant connect to internet
Hi ianzky, If the PC with the ECS P4VMM2 motherboard is connected to a network with a hub or router check if you can see the other PCs assuming their sharing is turned on. If yes then it is possible that you have to simply set the IP Add, Subnet, specially the Internet gateway and DNS in your IP/Networking configuration of the P4VMM2 PC assuming you want to manually install these numbers and not to Auto Obtain. Just make sure you follow the numbers of the other PCs except for the last digit(s) of the P4VMM2 PC IP Add. If you can not see the other PCs in your network, then it is possible that your lan cable is defective, try checking if the lights in your hub/router and/or at the back of your lan card lits up when you plug your cable both ends. If yes then it is good if not you have to replace your cable. Since you installed a new LAN card, I will assume that you have checked if the drivers are installed in the Device Manager and there are no conflicts or yellow mark(s). Both versions of the ECS P4VMM2 (7.3 & 8.1) have built-in LAN, if you want to continue using the new lan card it might help conserve resources if you disable the built-in lan in your bios or use the original built-in lan instead and reconfigure. In Win XP, try uninstalling the lan in Device Manager, on reboot it will be auto reinstalled and you can manually configure again. If by a remote chance that you are using 98SE, try checking your root file MSDOS.sys and see if there is an entry that say Network=0, change it to 1. I doubt if the motherboard is defective since you already tried installing a new lan card. Good luck. Pls post again how things turn up. Kind regards.
Jul 21, 2007 | EliteGroup P4VMM2 Motherboard
Toshiba Satellite A105 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
