I have the Sony KD34XBR2, a great TV... Purchased in 2002 and never had any problems UNTIL I was fooling around with the original remote (haven't used in years) and looked at the ilink button. I inadverently hit it and then by mistake hit the power button. Now it won't come on. Just the blinking light, 7 blinks. I hit the up button with hitting the power button, unplugged, let set, etc..... talked to customer support and have an appt for Friday... I am not a patient person... Can you help?
  • shortymeekba Feb 18, 2009
    Once again,,,,,the same problem. I am unsure about voltage? circuits? I am a lay person and trying to avoid the high cost of inhome repair. Isn't there something I can do? Is there a reset button on the back or something? I would look, but it's VERY HEAVY and I am not even 5 feet tall!! It's in my entertainment center... Please, something else I can do?
    Not that I am disputing the first two solutions, but would someone else clafify this? A third person to explain it a little better for me? Thanks.....
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The iLink button and power button simultaneous pressed did not cause the problem, it was just coincidental. The blinking lights indicate that auto-protect mode has been engaged and the 7 blinks refer to an error in the horizontal/high-voltage section.
Unfortunately this type of problem is not an easy user repair. This of course would require opening the Sony TV, familiarity with electronic components & circuitry, use of a DVM/VOM and a soldering iron.It would be to your added advantage access to a Service Manual or at the very least a schematic diagram. Repairs would involve working in the high voltage section, continuity checks and voltage measurements. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would be to seek the services of a qualified professional. Factoring in the length of years in service of the Sony, the expected cost of repair, downtime and efforts required to effect a repair, you may want to re-evaluate your options and consider replacing the the TV. Sorry but have to state all the options.
Good luck and thank you for using FixYa.
Posted on Feb 18, 2009
  • 217 Answers
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
It will need a service technician.
  • Saroj Sharma
    Saroj Sharma Feb 18, 2009
    Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 10,594 Answers
According to service manual of KD-34XBR2, seven blinks code means Horizontal deflection is stopped and qualified TV tech will fix it as novice should not try to repair this kind of problem.
Below is an image of service manual.. source of technical information.
    Genius:
  • 1,550 Answers
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You need to replace regulator it will cost you around $30-40 .
  • 19,396 Answers
The TV is on protection mode because a wrong voltage from main had been detected.
Unplug the TV overnight, so that you drain ower completely, this should fix the problem.
If that does not fix the problem, then the TV has a bad power board that must be replaced.
  • 265 Answers
Hi Matey
This is the owners manual i have found for you. Click Here
You should be able to find your troubleshooting for the remote.
hope this helps
alex
  • Alex Keen Feb 18, 2009
    I just had a scroll through and its got everythink you will need :)
    Please rate
    thanks
    Can you please click my link and have a read through this manual, this will tell you your problem and how to sort it.
    thanks
  • 4,234 Answers
The 7 blinks indicates a high voltage shutdown. The 33,000V line limit as exceded. Usually this is a problem with the regulator circuit. It is coincidense that the problem occurred at that time. The regulator part is about $25 or so.
Dan
    Brigadier General:
  • 8,619 Answers
Hi!
This occurs when High voltage shutdown happens. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • 1 more comment
  • Rylee Smith
    Rylee Smith Feb 18, 2009
    To clear this please turn off the TV for 10 minutes and then switch it on and then do the following
    Clearing is done by going into the service mode (press display then channel then Channel 5 button then  volume plus and then power  button). Press 8 and Enter, which returns everything to the factory preset condition
  • Rylee Smith
    You can try and reset the TV, if its not the hardware issue  it will reset it else its a Harware issue and you need to power supply circuitry. And, that would need a qualified technician.
    So, before goin to tech. try and reset it.
    Thanks
    Rylee
  • Rylee Smith
    You can try and reset the TV.
    If its not the hardware issue  it will reset it and if doesn't then its a Harware issue and you need to check power supply circuit. And, that would be done only by a qualified technician.
    Thanks
    Rylee
    President:
  • 2,110 Answers
  • Sibananda Jena
    Sibananda Jena Feb 18, 2009
    There are two components that you should check in the power sup. are
    T8005,and Cap 6532.This is not a repair that can be done by a novice,.
    Good luck and tell us how you made out on this set.
    Brigadier General:
  • 3,614 Answers
Check all loose connections from your tv.
I need a code for my sony tv please
Codes for your sony TV
4 digit code
0128 0013 0002 0071 0380 0152
3digit code
002, 006, 013, 071, 128, 380
3digit code(purchased before August of 2002)
002
Thanx
Jul 29, 2010 | GE JASRM24912 Remote Control
None of the universal remotes work.,
Try website like 1-800 Remotes Factory Original.Buy the exact remote to the original.
May 07, 2010 | Curtis-Mathis CM27101S TV
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
The Channel display will not turn off.
You will need the original remote and press the display button until it says off.
Bummer you don't have the original remote.
You can check out remotes.com and input your model number.
I hope that this helps you out.
May 05, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony TV
TV in A1 condition with stand / table worth for $200 and seems OK.
Mar 23, 2009 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Disney Princess TV
You can get the original remote on Ebay. I purchased one for my tv and it works great. Plus it's pink!!!! If I were you I would look there to see if you can get the original one, rather then messing around with universal ones!!!
Good Luck!
Oct 24, 2008 | Disney Princess MCP DVD2050P DVD Player
Remote does not work for TV
I assume you had new batteries in the original remote and that the Universal remote was programmed correctly for your TV.
Are there any lights on the old remote that flash when you press a button? If so, does it light?
If the TV doesn't respond to a remote, and the remote is verified to be in working order, then the infrared sensor in the TV is defective amd needs replaced.
Good Luck,
- Jim
Jan 27, 2008 | Sansui TVM1916 19" TV
Cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
Reprogramming TV Stations
Kathleen,
Don't you just hate that when the co-executors are so careless. :) (just kidding :)
You will need a remote but that's easy... Go here: http://www.miracleremote.com/ and get a miracle remote for a sony and they are as if you purchased the original remote. We have serveral here in the shop for various brands and they access all the functions of the original for a fraction of the cost...
Then just go into the menu and do an auto-program from setup.
Have a great day!
Bill
Dec 09, 2007 | Televison & Video
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
