Question about HP Photosmart 8050 InkJet Printer
Photosmart 8050 gives C1AB0001 error
When printing an envelop the printer stopped and gave me a C1AB0001 error. Even the power button no longer works. Printer was working fine all morning.
5 Suggested Answers
SOURCE: Printer Error When Printing Envelopes
I had problems printing 4 X 6, and found out that I needed to go into the printer mode, and change the tray feed from "main tray" to photo tray.  Try that one.
Posted on Apr 25, 2008
toddg
  • 171 Answers
SOURCE: Print Envelopes on HP Photosmart 7280
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Posted on Oct 07, 2008
PABLOCSA
  • 1124 Answers
SOURCE: I have a HP Photosmart
You will find how here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=3204464
Posted on Nov 18, 2008
SOURCE: HP Photosmart C5200 inkjet printer:
I found an instruction manual online and this took me through the whole procedure using word and using the CD/DVD drawer to hold the envelopes and now all is well. thank you
Posted on Nov 19, 2008
SOURCE: need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Posted on Mar 07, 2009
I have an HP 8050 and it says out of paper and it is not out of paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......
Good Luck!!!!!
Sep 23, 2011 | HP Photosmart 8050 InkJet Printer
HP Photosmart 7450/Mac OS X stops mid-print and light flashes
What kind of problem did you experience... Is there any error message appear, or it was ejecting the envelope instead of printing, or it prints but nothing was printed..?
Jun 05, 2008 | Canon BJC 4400 InkJet Printer
Have a HP Photosmart 8050. Won't Print. In the
go on web site www.hp.com they will answer your question after putting in you model number of the printer you have
Jul 27, 2010 | HP Photosmart 8050 InkJet Printer
Is the hp photosmart 8050 wireless capable or do i need to buy a wireless adapter?
The HP Photosmart 8050 is capable of using wireless when you purchase the HP Wireless Printing Upgrade Kit (Q6236A) 9f0c5cc.jpg
Oct 05, 2009 | HP Photosmart 8050 InkJet Printer
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
Need to print a half-fold card envelope with HP Photosmart C4480
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
Jul 29, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart 8050 InkJet Printer Logo
460 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
