Question about Aloha Housewares (93645) Ceiling Fan
Light bulbs burn out
I have had the Aloha Breeze fan for about a year ; the fan works great, very little noise, pleasant breeze. uses Candelabar Base Bulb 60wt max The main problem is the bulbs keep burning out within a few weeks of installing them; I have tried to purchase different bulbs to make sure I was using the right kind and I certainly haven't exceeded the wattage. The model # is 99645 42" white
I have wondered if it's possible that the way I installed the wiring does this ; it puzzles me though because it does work properly.
  • pfd3587 Mar 14, 2009
    SAME PROBLEM. i have used the bulbs designed for dceiling fans and it does not help. Also once the bulbs blow the remote will no longer control the dimmer or lights to turn them on or off.
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
Posted on Mar 08, 2009
I have a aloha breeze 32" tower fan. The base
Unfortunately from the manufacture sorry
Feb 21, 2013 | Dryers
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
Base is broken, can it be replaced
If it's an aloha breeze, u can email them @
Sep 14, 2009 | Tower Aloha Breeze Fan
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
I had a little aloha breeze fan/heater model
Consumer Product Safety Commission.
Go here:
Click on the "report" link and provide the information requested.
Jun 03, 2009 | Tower Aloha Breeze Fan
Installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Dec 03, 2008 | Aloha Housewares (93645) Ceiling Fan
Breeze ceiling fan not working
We were able to get 3 fans running again by replacing the capacitor which had melted in all 3 fans. On one of the fan's the casing around the motor was extremely hot, which prompted us to act quickly. I suppose the fan had been trying to start itself. We purchased the capacitors at an electrical supplier at a cost of $15 each. We were not able to locate the type of capacitors which came with the fan. I am now looking for replacement capacitors at a lower cost if possible. Does anyoe have suggestions of a reputable online dealer for capacitors at a reasonable cost? I would like to keep some on hand.
Apr 29, 2008 | Aloha Housewares (93645) Ceiling Fan
Aloha Housewares (93645) Ceiling Fan Logo
405 people viewed this question
Top Aloha Housewares Dryers Experts
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
