Question about Dell Dimension 4600 PC Desktop
Replacing monitor on a Dell 4600C w/ Acer monitor X183hb
Will Acer VGA 15-pin D-sub signal input type be compatible w/ the
4600C?
  • Dell Master
  • 13,433 Answers
Hey,
Yes, if the connector does not fit then you need a DVI to VGA adapter.
like this
http://www.thebidfloor.com/images/video_cards/DVI_VGA_ADAPTER.jpg
and it will work.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 18, 2009
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
A blue display box continually pops up with Input Select D sub DVI. I am thinking it is something to do with the monitor. What is wrong?
This monitor has two types of video inputs, a 15 pin VGA D-sub connector and a DVI connector.
If the video card has a 15 pin D-Sub then connect the video cable to the 15 pin D-Sub connector on the monitor.
If the video connectors are DVI then connect the video card and monitor with a DVI video cable.
You will also need to configure the monitor for either the D-Sub or DVI video input.
Aug 03, 2011 | BenQ FP91G+ 19" LCD Monitor
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Cannot read the model number (chinese) I known i have a flat screen monitor 20 inches from DELL 2004 I want to connect it to my Inspiron 1100 .I need instructions this an handme down so I have no...
    Since the cable you're describing is a VGA cable with the 3-row, 15-pin configuration, it will be the 1:D-sub selection. The DVI choice is for HD TV or a display card with HD capability. The S-Video is more commonly used for higher clarity video signals--less than HD of course, but approximately 15% to 20% sharper than a co-axial cable signal. (Reason: co-axial cable has all the color sigs squashed together while s-video splits them out into separate feeds.)
    Sep 15, 2009 | Dell Computers & Internet
    VGA connector wiring detail
    Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
    Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
    TV Monitor
    Hi Lylell, Your LG Studioworks 221U Monitor's input uses either a D-Sub which is a standard 15 pin vga cable or a 13W3C cable which is for cad workstations. On the other hand the output of your Dish Network receiver is either RCA-type audio/video or an S-video output. Since all are not directly compatible you would need something in between and not just cables. Technically what you need is to convert composite video output to d-sub 15 pin video input. A fine example is COMP2VGA by www.startech.com originally designed for gamers. There are some in the market that are simple connector to connector such as in http://www.trianglecables.com/1footvgadbma.html, please don't bother since it has been known not to work. To complete the setup, you would need a stereo amp/speaker pair for the audio out of your receiver. Hope this be of some help/idea. Post back how things are or should you need further information. good luck and kind regards.
    Aug 25, 2007 | LG Studioworks 221U Monitor
    Dell Dimension 4600 PC Desktop Logo
    74 people viewed this question
    Alun Cox
