Question about AT&T 8925 Tilt Smartphone
I want to change the color of the text on the start screen. The text is white and I am using a light colored background picture. Does anyone know how to change the text color?
I finally found "tdyscheme changer"
http://mobisapienz.com/index.php?option=com_jdownloads&Itemid=82&task=view.download&cid=74
The name of this is UI Tweaker and it contains the TdyScheme Changer. Works like a charm! Thank you for your response!
Posted on Feb 19, 2009
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
How do i change the screen size -resolution on my computer?
Windows 7 Starter edition comes with one desktop background, which can't be changed or customized. Please see this link for details.
http://windows.microsoft.com/en-US/windows7/Personalize-your-computer
To change the desktop background
  1. Open Desktop Background by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Desktop Background.
  2. Click the picture or color you want for your desktop background.
    If the picture you want to use is not in the list of desktop background pictures, click the Picture location down arrow to view other categories, or click Browse to search for the picture on your computer. When you find the picture you want, double-click it. It will become your desktop background and appear in the list of desktop backgrounds.
    8456a207-d4c8-401d-8729-c5dda3f0e72c_15.pngLook for pictures in other locations on your computer
  3. Under How should the picture be positioned, choose to have the picture fit the screen, tile, or be centered on the screen, and then click OK.
gl_ico.pngNote
If you choose to have a centered picture as your desktop background, you can also have a color background to frame your picture. Under How should the picture be positioned, click Change background color, click a color, and then click OK.
Feb 10, 2012 | E-Machines eMachines Desktop PC
I have an Acer windows 7 laptop. bt it seems that the wall paper cannot change. i dont know if I cant change it or it cannot be changed. please help. what should I do?
  1. Open Desktop Background by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    8456a207-d4c8-401d-8729-c5dda3f0e72c_65.jpgLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
gl_ico.png Note
If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
gl_ico.png Tip
To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
7abb27d7-2989-4144-81e3-0a51f703885d_50.jpgThe Set as Desktop Background option
You can add more desktop backgrounds to your collection from the Personalization Gallery on the Windows website.
Aug 31, 2011 | Acer Computers & Internet
My iphone suddenly changed colors. The pictures all look like b/w negatives. The icons are really weird colors. Help. Thank you.
Hello Michel,
In the iphone 3GS there is hidden feature called the "White on Black". It completely inverts the color scheme of your iPhone. The background on the home screen will be white, and the text will be black.All of your native apps will have an inverted color scheme. to disable this feature, Go to Settings then General then Accessibility then Turn of White on Black.wirelessage.jpg
May 19, 2011 | Apple iPhone 3G
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Sidekick ID
The white screen may be an indication that the lcd connector has come.
Follow the instructions at the following link!
Fix Sidekick ID white Screen
Apr 11, 2008 | T-Mobile Sidekick ID Cellular Phone
Unwanted color printing
assuming you are using a browser have you gone to file page setup and uncheck the background printing of colors.
otherwise we need more info
OS , software application used, usb /network printer ,model printer
any changes made recently. etc..
Apr 02, 2008 | Computers & Internet
Game
tune down the settings in game. example: changing screen resoloution from 1200x1000 to 800x600, also decreasing the quality may help. another thing you can try is exiting ALL applications that are running while the game is running that are not needed, such as any downloading clients or anything that may be using up some of your computers processing speed.
Sep 12, 2007 | Video Game Consoles & Games
Closed caption text is pale white now instead of bright green
Theres no color option on this set as far as the manual says. It sounds like the Video driver comming out of the microprocessor is bad, so the micro will need to be replace. This is not a user replaceable part so please seek a pro to repair this for you. Sorry i couldnt assist you more with this. Good Luck
Jul 01, 2006 | Quasar VV-1319W 13 in. Combo
Open Questions:
AT&T 8925 Tilt Smartphone Logo
238 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
