Question about OKI C9600hdn Laser Printer
Oki c9600 printed image washed lines. Only in full color mode.
Image wash when print full color.
Like cleaning toner with a broom???
Help please.
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
  • 95 Answers
SOURCE: Oki c9600 printer - waste toner box
Did you first try and dump the waste toner out of the waste toner bottle? If so it never completly gets empty. It is compacted at the end where the opening is. When the mach fires up the gears that drive the waste bottle break.
Posted on Mar 11, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
How do i print borderless
you cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
Sep 17, 2014 | OKI C3200n Led Printer
Printing of blank lines...
Since you didn't state how old the printer is or how many pages it has on it, my best bet that the drums are going bad, if you provide me with further details i can help you more
Mar 25, 2010 | OKI C5100n Laser Printer
Uneven printing]
Your cartridge is not able to supply that density of ink for that number of lines of solid color.
Could be any of the following:
1. Dirt in the cartridge
2. Low ink level
3. Bad ink in a refilled cartridge
Solution:
1. Print 1 copy in "draft" mode to see if cartridge can keep up. If so, it is simply ink supply... Replace cartridge, refill cartridge.
2. Run the "Clean" maintenance routine before trying to print a strong demand image.
3. Replace the printer for a quality image device (laser is best, all others are less). Good quality HP is better in inkjets. Decent Lexmark is fair - but VERY expensive to own/run/maintain. Kodak is cheap enough to buy and keep filled. Reliability is a potential problem...
Hope this provides some useable insight. -Jim
Oct 23, 2009 | Computers & Internet
I bought a used Color Laser printer, the HP1600, and I have just installed three brand new color cartridges. When I attempted to print the color came out washed and very faded and you could see it being...
This could a problem with the laser scanner assembly. It gets contaminated with toner and dust so reduceing the laser intensity which in turn causes the image to be fainter and gives it a washed out appearance. You would need to remove the scanner and clean the lenses and mirrors for each toner cartridge. The laser scanner box is one unit with four mirrors and four lenses in it.
Oct 07, 2009 | HP Color LaserJet 2600n Printer
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
May 13, 2009 | OKI C3100 Led Printer
HP Color Laserjet: ghost images, both black and color print jobs
Hi
sounds like either you fuser rollers need to be replaced or you need a new drum and cleaning blade, those 2 items will cause ghosting,
good luck
Jan 28, 2009 | HP LaserJet 2605DTN Color Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Lines printing through color images
DEAR, Maybe your printer is doing trouble due to rufness so do so oiling on the cartage rode try it definetly it will work thanks & vote me
Sep 21, 2007 | OKI C5800Ldn Led Printer
OKI C9600hdn Laser Printer Logo
186 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
