Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
DCR-HC42 doesnt work with batteries
My camera suddenly stopped working with batteries. When I connect to the power supply through the power adapter, it works fine.
But when I pull the cables out and try to run on batteries, it doesnt.
I bought a new battery and an external charger to charge them. The batteries are charged up for sure.
Any ideas on I can fix it?
    Problem Solver:
  • 13 Answers
I recommend you taking this into the nearest BatteriesPlus...they can test your batteries to make sure they are good. They can also help figure out the problem. www.batteriesplus.com
Posted on Aug 04, 2010
No power to camcorder when i plug up charger and will not charge battery
is you charger working?if you have background in eletronics you may use the multimeter and see if the required voltage is present.
if the voltage(required written on your adapter) is present,make sure the cable is correctly connect and then if the problem persist you can change the battery(get a new or put another from your friend to see the real problem)
thank you
Aug 28, 2012 | Sony Handycam DCR-HC42 Mini DV Digital...
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
My sony hadycam lcd stopped working
My LCD touch screen not function suddenly.After some days later totaly not display the LCD.But view finder has working Properly.
Dec 30, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Lcd screen not working on sony dcr hc 42e
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY DCR-HC42 - auto focus will not work ???
that problem is on the lens assembly...one the two motor is not working properly...sometimes it is a poor connection to the socket of the main board...other is photo sensor of the lens(not the ccd image sensor)or the driver ic of the 2 motor...i suggest you have to go the service center for repairing you camera cause it need to disassemble the camera for doing this....
Oct 12, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Tuch screen not working
the connection of the control button of the lcd panel is cut....check the flex wire of the lcd
Jul 19, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
64 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
