Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water runs over the top of the drum when in the wash cycle
I have put the timer in different positions with no response ,other than when i put it in the spin cycle it will work
    President:
  • Whirlpool Master
  • 2,651 Answers
If water continues to over flow the tub, you have an issue with the pressure switch / and or connecting hose, you can acess the pressure switch by removing the 2 screws ( look directly over the console to each side you see a phillips secrw un screw them and the consloe will flip back you see a small plastic hose to the left connected to your water levle switch. either it come undone( maybe form the side of tank ) ot ther is a hole/tear in the line
Posted on Feb 21, 2009
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
My perfoma washer is not working on the last Spin CYCLE
timer bad as far as balance is unit level on flat surface
Jan 18, 2010 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Washer timer advances all the way to off, but never stops. washer just keeps spinning. new timer is not the solution.
IF THE TIMER HAS BEEN REPLACED AND SOUNDS LIKE IT'S WORKING THERE HAS TO BE A WIRE OUT OF PLACE. THE TIMES HAS CONTACTS THRU OUT THE DIAL TO PUT MACHING INTO DIFFERANT CYCLES AT THE STOP CYCLE THE WASHER SHOULD STOP IF THE CONTACTS ARE GOOD
Sep 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
The machine when it is on a cycle sticks on the rinse spin
hi..most likely the timer switch which might have got
into trouble,this controls all the different cycles.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
