Question about RCA RCR412C Remote Control
No code search button
I want to program my ty/dvd/vcr combo, but there is no code search. what do i use in place of the code search button
  • brittjay1 Feb 26, 2009
    I have this same prblem With a Norcent TV
Turn on your TV, hold down tv or vcr/dvd depending on what you want to program. Then enter the codes this site gives you. http://remotefinder.rca.com/default.aspx?site=rca. Then release tv or vcr/dvd and see if your remote will change the channels.
Posted on Feb 27, 2009
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
Programing rca remote for dvd/vcr combo
all you have to do is press and hold code search when the light shows up let go of code search then press VCR and it will blink onces and let go of VCR and press OFF/ON about 50 times and then press enter onces and there you go
Feb 04, 2008 | RCA Universal Remote 3 Device Remote...
I need the codes
Here's how:
Turn on the electronic you will programming the code for.
Press and hold the CODE SEARCH button until the red indicator stays on, then release the COE SEARCH button.
Press and RELEASE the desired mode button (TV, VCR, etc.). The red indicator blinks quickly, then stays lit.
Enter the 3 digit code from the code tables.
With the device on, press CHANNEL UP on your remote. If the device responds, no further programming is required.
Panasonic DVD/VCR combo code: 345
Nov 30, 2007 | Philips PM4S Remote Control
RCA RCR412C Remote Control Logo
302 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
