Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
USES only 2ghz instead of 3
I have a intel 3ghz ht processor but it uses only 2ghz how can i solve this problem
there is no option in the bios about ht
and i am using asus p4s533-tvm board
Have you just installed this processor as an upgrade?? Check the jumper settings on the motherboard and the multiplyer in the bios.You need 133Mhz clock speed. With the multiplier of 23 which is set in the bios automatically by the CPU id 23x133 = 3.06Ghz. I suspect that the jumper settings are for 100Mhz so 100x23 = 2.3Ghz. Let me know how you get on or if you have any more questions as i have the same motherboard and im gonna buy one of these processors @ Lecousi@yahoo.co.uk
Regards
Lecousi
Posted on Mar 16, 2009
The comptuer is ringing everytime i cut it on and won't boot up
Open cpu cabinet then reconnect RAM memory . Reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet. Pull processor and it's fan. Reconnect PCI or vga card if any. then check. Make sure bios recognized harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Dec 27, 2010 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
What processor can use to upgrade my Pentium 4 2GHz in my HP M1270
HP Media Center M1270n desktop PC?
Here are the Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00280666&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
Here is the Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00297771&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
The Asus PTGD1-LA motherboard, is a Proprietary motherboard, made Especially for HP.
HP's name is PufferM-UL8E
You won't find it on the Asus Support website.
Fortunately, HP listed basic information for CPU (Processor) Support.
When you look to the right of the CPU/Processor heading, you can see it states -
A) Socket LGA 775 (Processor socket)
Looks like this,
http://en.wikipedia.org/wiki/LGA_775
Processors that fit this processor socket, have the socket holes.
775 of them.
The LGA 775 processor socket, has the pins that go up into the socket holes of the Processor.
775 of them.
[The Socket 478 processor socket, that was before the Land Grid Array 775 processor socket, has the socket holes (478), and the processors that fit this processor socket, has the pins. {478 of them]
B) Supports processors with up to a 3.8GigaHertz frequency rate.
3.8GHz.
['Speed' is a slang term for Frequency Rate.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
3.8 Billion Cycles per Second.
Can also be stated as 3800 MegaHertz.
Mega = approximately 1 Million ]
C) Can support Intel Pentium 4 processors with HT.
Hyperthreading Technology.
D) Looking to the right of the Front-side bus (FSB) heading, you will see it states -
800MHz.
This means the Asus PTGD1-LA motherboard will support Pentium 4 processors with,
1) HT
2) UP TO a 3.8GHz frequency rate
3) Up to a FSB frequency rate of 800Megahertz.
4) Use an LGA 775 processor socket.
Now let's look at one example, of a chart of Pentium 4's with HT, that fits these specifications,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
See the heading - Prescott (90nm)?
This means the processors in this chart, are based on the Prescott Core, and the 90nm architecture.
(nm stands for NanoMeter. Approximately 1 Billionth of a meter)
Looking at the headings in the chart, you will see Model Number, sSpec Number, Frequency, L2-cache, Front-Side Bus, Multiplier, Voltage, TDP, Socket, Release Date, Part Number/s, and Release Price.
At this point I would only concern myself with the,
Model Number, (If applicable),
sSpec Number,
Frequency,
FSB, (Front Side Bus),
Voltage,
Socket,
and Part Number(s)
1) Model Number:
The older Intel Pentium 4 HT processors did not have a Model Number.
Intel didn't start using a Model Number until later.
Model Number examples start with 517, 520, 520J, and so on.
Look for the sSpec Number, and the Part Number, for the older Pentium 4 HT's. They're printed on the top of the processor's case, and should be listed by the seller.
2) sSpec Number:
Intel brought this out.
Their way of marking a processor.
Another identifier for you to use.
3) Frequency:
The Maximum frequency rate, ('Speed'), that the Processor is supposed to be able to operate at.
4) L2-cache:
The small memory area for the Processor. The Processor accesses this small memory area first, because it operates at the same frequency rate as the Processor.
You can't change it, and 2MB of L2-cache, is the largest size for an Intel Pentium 4 with HT.
Just thought I would include this information.
(Ram Memory is next. Typically, Ram Memory operates at half of the FSB frequency rate. The Harddrive is next)
5) Front-Side Bus (FSB):
The frequency rate that the Processor transfers data (Information) to the Northbridge chip, and back from the Northbridge chip.
More on the Northbridge chip in a moment.
6) Voltage:
Pretty self-explanatory. The Voltage range the Processor will use.
You need the Voltage range of 1.25/1.4 Volts.
(1.25 Volts to 1.4 Volts)
Any Processor (That is Intel Pentium 4 HT, Socket LGA 775), that uses Voltage in this range will work.
7) Socket:
The type of processor socket that the Processor will fit in.
Has to be LGA 775.
8) Part Number(s)
Self-explanatory again.
The Part Number, that is stamped on top of the Processor's top case.
Part Number(s) is listed, because there may be more than one Processor in the Model Series, that fits the same specifications.
If there is no Model Number, refer to the sSpec Number, or Part Number.
The largest frequency rate (Speed) of Processor you can use, is a Pentium 4 HT that operates at 3.8GHz. (And fits in an LGA 775 processor socket)
Barring that a Pentium 4 at 3.8GHz cannot be found, you will know what Processors you Can use.
Scroll across the headings with your eyes, and start under the Frequency heading.
Find the frequency rate ('Speed') you wish to try.
Go across to the Front Side Bus heading. You should look for a processor listed that has an 800MHz listing.
Look at the Voltage.
All of the Intel Pentium 4 HT processors that fit in an LGA socket, use an 800MHz FSB, and are in THIS particular chart, fall within the same Voltage range.
Keep the Voltage range in your mind, as you look at the other charts below this one.
Socket.
You know you need a processor that fits in an LGA 775 socket.
Look at the chart below this Prescott Core (90nm) example.
Prescott 2M Core (90nm)
Use the above criteria above in this chart.
I wouldn't recommend any Pentium 4 HT's, in the Cedar Mill (65nm) chart.
It isn't that the architecture is smaller (65nm), but that the BIOS program,and version on your motherboard, may not be able to handle these processors listed.
I also do not see a BIOS update for one, and for two, if you make a mistake when performing a BIOS update, your motherboard becomes an expensive Frisbee, or doorstop.
You also do not want any of the processors listed under the Pentium 4 Extreme Edition heading.
(Mobile Processors are for laptops Laptops are M-O-B-I-L-E)
Northbridge chip.
1) The Northbridge chip, and the Southbridge chip make up the motherboard chipset.
(Does not apply to the new motherboards that support the Intel i3, i5, and i7 Core processors)
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster processes of the computer.
Processor, Ram Memory, and High speed graphics.
(AGP or PCI Express. Not a graphics card in a PCI slot, nor Integrated Graphics on the motherboard. These are slower processes of the computer)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Processor
Memory Slots = Ram Memory slots)
Looking at the diagram, you can see the slower processes handled by the Southbridge chip.
Looking back at the Motherboard Specifications, look across from the Chipset heading.
Northbridge: i915P graphics and memory controller hub
(MCH)
Southbridge: ICH6 Intel I/O Controller Hub 6
Uses an Intel 915P Northbridge chip, and an Intel ICH6 Southbridge chip.
Jun 27, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
I have an ASUS P5S800-VM Motherboard socket LGA775
To answer your question, yes it's possible.
I'm sure you wouldn't like it if I left it at that, so I'll explain a bit more.
It's about as simple as this: The processor you want to install into the motherboard is for an LGA 775 mobo such as yourself. Therefore, it should have no problems when you put it in.
Hope I was of assistance.
Nov 28, 2009 | ASUS P5S800-VM Motherboard
What mb to update from kk266plus for modern pc
you can buy DG31PR,GL / DG45PR these series mother board but you have to change your processor too with core2 duo 2ghz series, if you want to upgrade the RAM to 4GB means this is the only way have to change the following specifications (DG31 or DG 41 series board, core2duo procc,SATA seagate hard disk 500GB, 4GB RAM) this is the complete solution .
Oct 20, 2009 | Gateway 560GE Intel Pentium 4 630 3GHz(HT)...
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
Intel cpu comparable to "Dual Core AMD Opteron 1212HE"
This is an AMD 2nd generation Opteron CPU, running at 2GHz. It is a single core device. So a comparison would be against Intel business CPU - the Xeon, again compare against a single core.
Apr 02, 2009 | AMD Opteron Dual-Core 1212 HE 2.0GHz...
Is it practical to install a faster processor?
most laptops do not allow for cpu upgrade. For the type of performance you seek it would be best all the way around to check into a desktop that will meet your needs
Dec 26, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor Speed Problems
Check your Power Options (located in the Control Panel) and make sure your computer is not throttling the processor to save power.
Nov 19, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
155 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
