Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Hotpoint wd420 not pumping
My hotpoint wd420 starts fine and fills with water but it just runs the same part of the programme all the time plus the water will no longer pump out i have taken the pump out and cleand out the ball filter how do iknow if the pump is any gud any more ?
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Posted on Dec 16, 2009
How do I get into check the pump for blockages on my hotpoint wmud942 washing machine, the key symbol is on all the time with door locked, when a programme is running the pump starts but then when it
I would suggest you fill the washer with water externally up to below the door level and run it in one of the short wash cycles. I would assume it will progress further into wash. This would suggest the inlet water circuit has a fault. I am hoping the laundry water tap was turned on when you were running the washer.
Best to replace the inlet valve and see. Worth spending the 20 quid.
Hotpoint WMUD 942 UK Washing Machine Valve
Sep 07, 2014 | Hotpoint Washing Machines
HOTPOINT LFT114UK not filling
Circuit board may have a short and fails to complete the administration of commands to the solenoids. Many times the timer section is effected by power surge and repeated use. Factory service is the only way to repair this , unless you are a technician.
Apr 15, 2014 | Dishwashers
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
The machine will not fill. There is a humming sound like its about to pump the water, and then nothing. Help!
if there is humming thats the sound of the valve ( water inlet opening) I DONT WANT TO SOUND SILLY BUT IS THE WATER TURNED ON it happens
take care
sonic boom electronics australai
Dec 29, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
Hi. Lots of water has started pouring from the drawer during a wash cycle. I use liquid detergent.
is the tub just filling all the time if so you have a fault on the pressure system or a blocked pressure pipe
Feb 01, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Hotpoint WF860
here is the list of code meaning from hotpoint.
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a service engineer
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer.
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a service engineer.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a service engineer.
  • F41 - Water level detect sequence incorrect. Book a service engineer.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
please do not forget to rate and comment about your experience with fixya.
Aug 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
440 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
