Pentax ZX-10 35mm SLR Camera Logo
A
Anonymous Posted on Feb 26, 2013
Fix shutter on pentax - Pentax ZX-10 35mm SLR Camera
1helpful
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
I have a Pentax ME Super and whenever I press the shutter button down, regardless of whether it's in auto, manual or 125x mode the shutter will stay open for the amount of time my finger holds down the...
One old camera. You have an electronic shutter and mechanical (backup) so you may have a dead electronic shutter. I would check the battery and contacts. If they are good... the shutter is bad. You have a standard K-mount body, any lenes will fit any Pentax camera, film or digital. The lenses will go on more modern Pentax bodies but will not auto-focus if on an AF body. These bodies are some 25+ years old, many places are selling them for $30 or so.. there are just thousands out there. If you want to stick with film, go for a newer AF body and you can still manually focus.
2helpful
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
2answers
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
4helpful
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
1helpful
Pentax optio 60
Your shutter is driven by a small motor attached to the lens assmbly. It could be that which has died or more likely you have a sticky shutter. A small knock or a drop of soda can stop them from opening. Try switching on and very gently with a cotton bud see if you can help open the shutters. Whatever you do don't force them and force them out of shape. You may have to do this a few times to get in sync with the power up sequence but if you can get both shutters to open fully you should be in business. If they keep sticking I've seen one guy glue them open. Personally I'd rather fix them so they do their job.
IstD shutter release problem
I've had similar problems with my Pentax Super-A on an intermittent basis. If you haven't replaced the batteries I suggest you try that first. Not sure why, but that has sorted my problem out quite a few times (even when the existing batteries still have a fair amount of juice left in them).
Pentax S4 no flash problem
Well this camera has no manual controls so it's merely compensating for the lack of available light by lowering the shutter speed. I don't think there's very much you can do about it -- maybe you can try to lower the EV -/+ setting (I forget what it's called, it makes your image darker or brighter). If the camera didn't lower the shutter speed you would simply get dark pictures where you can't see anything
Top Pentax Photography Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pentax Photography Expert? Answer questions, earn points and help others
