Question about Sylvania LC320SS9 32 in. LCD TV
Sylvania LC320SS9 HD LCD TV Closed Captioning not working
I know that it will not work with hdmi. However when I try a direct connecton from cable (no box, just basic comcast cable) to the TV, and through setup, detail, captioning, it still wont let me choose CC1 to turn it on.
It says that there is a cc decoder inside and supports digital/analog cc however it won't even let me choose cc1-
So what am I missing here?
  • 2 more comments
  • wolfance Feb 18, 2009
    (Nice job presuming I don't read the manual)
    Can't you tell I read it by the steps I provided- Setup, detail, CC, (I tried BOTH conv or digital CC) and entered- then when it displays CC1, it can be "selected". Simple as that.
    To trouble shoot, the same hookup (direct cable to my sdtv) showed CC coming through the TV normally, but when hooking up to this HDtv, CC will nto come through and I can't choose cc1 at all.
    (p.s. I'm pretty skilled with connections, I can connect dvdr, vcr, xbox, cable, old decoder, tv, etc- and rebuild computers, etc) Just to give you an idea of my aptitude in this which is why I was truly shocked that this HDTV would not enable CC although it adversates as having CC option. but doing research, it appears that HDTV ITSELF can not do CC at all. (google closed captioning on hdtvs)
  • wolfance Apr 21, 2009
    CC will NEVER work on the side panel, you MUST use the remote to turn CC on. That's the solution.
  • Anonymous Mar 18, 2014
    None of the selectable options show CC's. HD Component cable connection to Comcast cable.
    Scholar:
  • 124 Answers
Well first you can view your TV's manual at
http://www.sylvaniaconsumerelectronics.com/pdf/om/LC320SS9.pdf
Go to page 24 through 27.
IF that does not help you, comment me back.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Posted on Feb 18, 2009
I am connecting a RCA DVD player (DRC277B) to my TV and have problems when using the HDMI cable. When I connect the unit using the AV Cable, things work OK. I then turned off everything and hooked...
Hi
Thanks for using FixYa. Two things that will cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the not available message. I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts
Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 15, 2010 | RCA Televison & Video
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Tip
HDMI Closed-Captioning won't go away
I bought this television yesterday, bought the HDMI cord and hooked it up through my Comcast digital cable box. Every channel would display closed captioning, despite it's supposed inability to support that function. In order to remove it, we had to turn off the cable box's ability to display closed captioning. To do that, turn off the cable box and hit menu to get to the setup menu. It is there that you will be able to turn off closed-captioning.
on Jun 16, 2007 | Sylvania 6626LG 26 in. LCD Television
I have a Direct TV remote that I need to program to operate my Sylvania HDTV model LC320SS9. None of the codes listed by DTV work for this TV. Do you have any suggestions for programming the remote? DB
hi! i have a couple of codes for your tv, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483, 1046, 1465, hope this helps! goodluck!!!
Feb 25, 2010 | Sylvania LC320SS9 32 in. LCD TV
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Nov 13, 2007 | LG 37LP1D 37 in. LCD Television
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Sylvania LC320SS9 32 in. LCD TV Logo
948 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Dave Naylor
Dave Naylor
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
