Question about Watches
I need to know how to wind up an old (1930's) Oris watch. It loses two hours a day and stops. Do you wind up just in one direction or back and forwards. I'm worried about overwinding it. If it needs attention, where could I get it fixed?
  • 2,334 Answers
Your watch is winding forwards only, but you can wind it both directions as the clutchweel does the job and disengages when crown is moved backwards. No worries about overwinding, as you will feel a substancial resistance when the spring is fully wound.
If your watch is loosing 2 hrs a day, then you need to overhaul it (full service). To do that you have to find your nearest watch repair shop and ask for help. Every decent watchmaker will be able to do the job.
Do not forget to rate, please.
Posted on Feb 18, 2009
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
Need help with ORIS Miles Complication 58175284061LS Watch: The hand for ''day of the week'' came/drop off and I wanted to get it put back in place. Will be sending it to Oris service centre. Is it...
most watch companys will only do this with a full service as you have found out wich is not needed i would find a good local repairer to do the hand replacement wich is only a 30min job..and yes you can use your crown or fit a new one remember to ask for a reseal for watch as well..as far as i know oris use a Valjou movement in this watch made by ETA of switzerlamd so parts hands etc are no problem for any repairer to buy and fit..
Mar 25, 2010 | Watches
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Hello. I just bought an Oris Williams automatic watch on EBay. I was able to get it started and adjust the day/date but it stopped overnight and now it will not re-start. I tried moving the watch around...
I presume they told you on E-Bay that the watch ran ok. If it was mis-representitive that's another story that you probably have some recourse through E-Bay to return and get you money back. If you are stuck with the watch, then it may just need a good cleaning by a reputible watch maker/repairperson. You can also purchase some rather inexpensive watch winding machines to keep the watch wound if you don't wear it all the time. Hope you get it working, Good Luck
Nov 17, 2009 | ORIS Watch Williams F1 Team Day Date...
Keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
Apr 08, 2009 | Breitling Navitimer A2332212 G5 431A watch
I have an Oris BC3 which was never a great time keeper; gaining or losing 5-10 seconds per day. Recently, it started to gain at an alarming rate and I took it to be cleaned and regulated at a watch...
Take your watch back to the watchmaker and ask to regulate the watch again. After a decent repair watch shouldn't loose or gain that much and if properly regulated and tested can keep good time. ORIS is using the same Swiss made ETA movements as Tag Heuer, Ebel, Montblanc, Tissot, Maurice Lacroix etc. These are very good mechanical movements and can be adjusted to allmost perfect timekeeping.
Dec 22, 2008 | Watches
Watches Logo
141 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
