Question about Yamaha HTR-5830 Receiver
Need to know how i can set up the diffrent settings on my yamaha
My rear sussound rear i can't get the sound up on it and also i had bought it from rent a center
    President:
  • 814 Answers
The answer to this problem should be in the owners manual for your product. Check the speaker wire connections and the speaker wire for possible broken connection points. Try moving the wire around and see if you get sound. If you do then you need to replace the speaker wire. If not then you need the connectors you are using on the wire that are making contact with the speaker and receiver. They all must be making good contact with the speaker wire to keep a good connection.if you find no problem with the speaker wire and the connectors, you need to try another speaker on the the wires to make sure that the connection is working.If all the connections are good and you are getting signal from the output, you have a problem with the speaker. If you have a warranty for your speakers then have the bad one repaired or replaced under warranty. If not you can try to repair the speaker by opening the cabinet and checking the input connections from the Input wire connector to the speaker. See if it has any cold solder joints that may not be connecting the signal to the speaker. If the connections look good.You need to look at the speaker itself and the electronics that may be use in sending the signal into the speaker. Look for bad or broken connections in the speaker and the components. The drive circuit may have failed and need replacing or the speaker itself may have a broken or a burnt coil. If this is the case you may want to replace the speaker. Take all the information printed on the speaker and the information in the owners manual on the speakers and write them down on paper and try to find a speaker that matches the specification. Buy it and replace it for the bad speaker.You can find information on you receiver on the www.yamaha.com website by using the customer service section and putting in the model number of your receiver. Check out the frequently asked questions and troubleshooting sections and see if someone else has had this problem or similar one and has had a solution printed.The number for Yamaha service centers is 1-800-492-6242 and for buying parts is 1-714-522-9888. You can use these numbers to get help from the service center in your area or buy parts for repairs from the dealers. I hope this helps you with your problem.
Posted on May 18, 2009
Yamaha FJ1200A torque settings for front and rear sprockets
Hi, Paul for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Front and Rear sprocket torque specs
Torque Settings
Yamaha 1992 FJ1200 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fj-owners-manuals
Aug 22, 2017 | Yamaha Motorcycles
Thunderace Rear Axle Nut Size and Torque Settings
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.thunderace.nl/downloads/yzf1000.pdf
YAMAHA YZF1000R Owner Manual
Jul 10, 2014 | 1997 Yamaha YZF Thunder ace 1000 R
RECEIVER KEEPS SHUTTING OFF
it sounds like you have the auto power down/auto power off turned on which is diffrent from the sleep time which can only be set for two hours and the auto power down/off feature can be set for many hours and is always on unlike the sleep timer which must be set each time, you will be able to find it in the on screen menus and turn it off since it is on the moment you turn your unit on and your owners manual will explain exactly how to do it and if you dont have the manual just goto www.yamaha.com and you can download the manual for free. please let me know if that was the problem
Jun 12, 2014 | Yamaha RX-V659 Receiver
I need to know how to set the timing on my 83 750 yamaha
Hi, Rickyalleng for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
need to know how to set the timing on my 83 750 yamaha Google Search
1982 XJ750 Cam timing pictures
Yamaha XJ750 Owner Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Feb 12, 2011 | Yamaha Motorcycles
What should all the torque settings be on a yamaha r6 2009 motorbike be?
Hi, Clare_musk for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/331674-front-rear-disc-rotar-bolts-torque-settings.html
Torque settings Yamaha R1 Forum YZF R1 Forums
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 08, 2010 | 2008 Yamaha YZF-R6
How to adjust my rear shock on a 2002 Yamaha yz426f
Hi, Joeybovee58 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Rear Shock Settings On Your Dirt Bike
MXWrencher com How to Set Your Suspension Sag
Yamaha YZ426F Owner Service Manual
Yamaha YZ450F Owner Manual Page 3
Mar 06, 2010 | 2002 Yamaha YZ 426 F
My yamaha did not come with the optomizer mic
You can, and the results might be better than not optimizing, but they might be worse.
The optimizing process listens for resonant frequencies in the room (what pitch "rings" longer in your room) as well as damped frequencies (what pitch sounds "dead" in your room)
To do this, it needs a mic that's matched to the unit.
Different mics have different frequency response curves, so your friend's mic might think (for example) that 2500hz is really hot, but the yamaha mic would think it's normal.
Certainly won't hurt to try, but if you don't like the way things sound after optimizing, then just reset your yamaha to the default EQ.
Sep 16, 2009 | Yamaha YSP-800 System
FZR 1000 1991: Torque settings on pivotarm axel nut and front chainwheel?
Hi, Trom_ma sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
angelfire com
Torque setting on Fazer 600 rear axle nut
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Exup1000 co uk Tech FZR1000R
Aug 11, 2009 | 1991 Yamaha FZR 1000
Bought a used dtxpress set pre-pogrammed.
The info is on pg.35 of the drum owners manual at http://www.dtxperience.com/dox/dtxp4_en_om_b0.pdf. Hope this helps.
May 11, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Mitsubishi WS 55859 Green light flashing
HELLO. WELL SOUND'S LIKE YOU A PROBLEM.!! THAT COULD BE A FEW DIFFRENT THING'S.!!! FIRST THING YOU WANT TO DO IS UNPLUG THE SET..!!! THEN TAKEOFF THE BACK.!!! AND LOOK FOR FUSE'S ON THE BOARD. TO SEE IF YOU HAVE A BLOWN FUSE.!!! GET BACK TO ME AND LET ME KNOW .? OK ASAP. "GOOD LUCK"
Jun 15, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Yamaha HTR-5830 Receiver Logo
163 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
