Question about Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop
Monitor displays alternating pattern of pink and blue stripes
I have 17" PowerBook G4 1.33GHz, 1.5Bb, 80Gb with monitor displaying faint alternating bands of pink and bluecomprised of a checkerboard pattern. Also shows up on my Cinema 23" display
  • 3 Answers
It sounds like your video card is failing and you need to find a way to get around it if possible?
Posted on Feb 18, 2009
  •  B Sea
    B Sea Feb 08, 2013
    Thanks Jim, My problem was with the older eMachine desktop doing a similar checkerboard' sequence & then locking up -only fix being a cold reboot. Problem is the video is on the MB. Do you think there may be any logs I can check on the PC to pin point the vid card?
Dell inspiron 15R win8/win7 dual boot went into coloured blocks, and pink and blue stripesi
I would say your Graphics Adapter is going. Has it been overheating? Have you cleaned the Fan, Vents, Heatsink? Have you connected to a External Monitor? If the problem follows to the external monitor it's likely a Graphics Adapter problem, which is a problem in a laptop. Have you tried booting to Safe Mode? In safe mode your windows software will use the generic graphics driver.
Jun 02, 2013 | Dell Inspiron Computers & Internet
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Hi, do i need an electrical cord to plug in to an electrical outlet to connect my syncmaster to my powerbook so that i can display on both monitors? or should the power from the powerbook be enough? thnak...
The monitor needs its own power supply, so it will need an AC outlet.. All the computer can do is send out the video signal to be displayed. If you were hoping to use the external monitor somewhere where you won't have AC power, you're out of luck. Sorry.
Jun 05, 2011 | Samsung SyncMaster 172 N (Black) 17" LCD...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Display problem
There are severals ways to determine what component is at fault, through some of them may require equipment you may not have on hand.
If the lines move, appear, and disappear as a result of changing the hinge angle, the problem is most likely in your LVDS cable, which is not an expensive part.
If they don't, then you need to attach an external monitor using the short white video dongle that came with your PowerBook. If the lines also show up on your external monitor, your logic board is at fault, which is an expensive fix and probably not cost-effective for a machine of this vintage. If the lines show up on the built-in LCD but not the external monitor, the problem is with the LCD panel itself, which is a medium-expensive part.
Apr 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop Logo
294 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
