Question about Ricoh Aficio 1015 All-In-One Laser Printer
Can't clean up lines on a ricoh 1015. Replaced the cleaning blade
  • 2 more comments
  • Anonymous Feb 19, 2009
    It has a new drum, The lines are before the fuser, I clean the drum and the lines are gone for the first copy then are back.
  • Anonymous Mar 09, 2009
    error kode sc320
  • quennie732 May 11, 2010
    The charge roll, drum blade, and drum are recomended to be replaced together charge p/n AD027018 was this replaced also? I assume internal prints are OK and lines go all the way to the edge of the paper.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are there lines on the green drum?
  • 46 Answers
Do the lines occur on copies made from the glass or the automatic document feeder or both.
From glass only:
Remove platen glass and clean optics (all the mirrors).
From ADF only:
Clean ADF glass. The thin glass on the left side of the larger platen glass.
From both ADF and glass.
Do a full PM kit including new drum and developer. Don't forget to initialize the developer.
Posted on Mar 14, 2010
Must be the drum itself then, or fuser??
Posted on Feb 18, 2009
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio 1800 .why copies are now black lines appear from top to bottom?
I guess you talk about Ricoh MP 1800.
The Black lines on the bottom appear because the copier has made more than 60,000 prints or more if new.
If it's bought used, than it has made 60,000 or more prints from the last change of the drum and the drum cleaning blade. For the print to be clean again, it will need to be changed the drum and drum cleaning blade. This copier as all other copiers have parts that have a yield.
Aug 25, 2016 | Ricoh Aficio Office Equipment & Supplies
Black line on copies
Check the drum history? If the yield is not yet reached, you should clean the charge roller, cleaning blade brush and cleaning blade. Remember to vacuum beneath the cleaning blade! See if that works, otherwise you should call a techie to replace the drum. If yield is not reached they will charge you for a new drum.
Jul 21, 2014 | Ricoh Aficio Office Equipment & Supplies
How to fix Drum & Cleaning Blade in PCU unit of Ricoh 1015
The PCU unit is one compact unit when included the OPC drum,drum cleaning blade,charge roller,developer .
Jan 25, 2013 | Ricoh Office Equipment & Supplies
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Jan 11, 2011 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 printing lines, seems to be photoconductor
Cleaning the drum will not help. Depending on many factors including drum condition, number of pages printed etc, you will need at least to replace the drum cleaning blade. This is a common cause of black streaks. The drum should have been clean. The fact that it has toner on the surface is pretty good proof that the cleaning blade is bad. The part number for the blade is B0392289. I would do a search for this part and get one before you even think about trying to deal with the streaking problem. Once you get the blade, if you are mechanically inclined then replacing the blade is not difficult.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Ricoh Aficio 1018D Copier
I have a problem with my Ricoh Aficio 2022sp. It leaves a black line when I copy or print anything.
Something around the drum need to be replaced. There are two ways to be done. Because Ricoh do not offer a replacement by parts around the drum unit for this machine by Ricoh you can only replace the hole drum unit. But as you say you have a problem with the drum cleaning blade, or in worse case the drum and the cleaning blade for the drum need to be replaced. So Katun offers a replacement by parts and by Katun is more cheap to be replaced. This is what is the problem, so on your hand is what are you gonna decide.
Dec 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1015 All-In-One Laser Printer Logo
366 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
