Question about Proscan 32LA25Q 32 in. LCD TV
Wall Mount won't fit screw pattern (405mmx200mm
I bought my Proscan 32" #32LB30QD, 12/28..I purchased a swing arm mount...the mounting panel is too small? Sears does not know how to help?
For $19.99 you can get an adapter.  Do a search for TV mount adapters 200x400 on amazon, or tiger direct, or the shopping site of your choice.
Posted on Apr 12, 2009
Need screws for the back of my TV.Wall mount screws for a sharp LC52D92U
If you have purchased a wall mount kit that will fit a 52" TV there will be screws included that will fit.
Mar 15, 2014 | Sharp Aquos LC52D92U Television
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
We purchased a planet 3 wall mount 66306 and it came with no instruction guide. Do you have one online?
i purchased a planet 3 model 66306 double swing arm articulatable lcd,plasma 36"- 63" mount but it did not have the 2 long mounting brackets that get mounted onto tv which allows you to hang tv onto mount. can i purchase a set or can you direct me to a site that i can??
Jul 20, 2010 | Televison & Video
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
We have no instructions for the wall mount on the entertainment system that we are using with the lg47le5400 tv. I would like to know what hole we use and what screws to mount it. we recieved no...
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Jun 26, 2010 | LG 47LE5400 47 in. TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32LA25Q 32 in. LCD TV Logo
305 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
