Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Flashing red status light wd62327 - Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Your lamp is getting ready to go!!! Better order a new on, it is approx. $236.00. I put a new lamp in mine (July 2007) just ordered another one this week. The first one that went gove me the warning of the flashing light, this time it just blew. I called 2 places and they said it is the lamp.You can order them online from Mitsubishi.
Posted on Mar 13, 2009
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Red light blinking no picture just sound
How many times the standby LED flashes at a time?
Aug 04, 2012 | Mitsubishi WD62327 TV
I have a 2005 Mitsubishi WD62327 62" rear
Yes, this kind of symptoms is not costly to repair. I can assist you which part gone bad on this error code. Click here.
Jdvillanueva
Oct 03, 2011 | Mitsubishi Televison & Video
Why is the Status Light on my Mitsubishi XL8U flashing red? My projector is still working but the status light flashes red.
With out knowing the state of the power LED, my best guess is the Status light is solid red and telling you to purchase a replacement lamp before the current one dies. Attached is a chart that will show you the errors possible depending on the LED statuses:
Mar 11, 2011 | Mitsubishi Lamp For Mitsubishi XL8U...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
I have a mitsubishi tv model #wd62327 it was on
Your user manual should give you the diagnosis... it is probably available on line if you don't have it. I would guess the fan is making noise and needs to be cleaned, lubricated or replaced. I hope this is helpful to you.
Oct 26, 2009 | Televison & Video
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
No power
they are located on the power pwb There are four 1000uf 16V two 3300uf 16V and two 2200uf 35V that need to be changed
Nov 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
340 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
