Question about Gigabyte Computers & Internet
I believe that my agp slot went bad so i bought a new video card that uses a pci slot instead how do i access bios to configure this when recieving this error code at post 1 long 2 short gigabyte motherboard
  • 3 more comments
  • henrichjerem Feb 18, 2009
    okay so i need to configure from the agp slot to the pci slot how do i do that when i cannot pass post
    that would be what i am trying to do yes. I have been at this for two weeks can you help
    I will thank you that is very helpful i will let you know how it turns out
  • Peter Steiert
    Peter Steiert May 11, 2010
    Okay, if the system doesn't post there's something else happening. Either you reset a frequency and it fried your system or you reset a frequency and need to reset the CMOS. If the system doesn't POST either the PCI slot you're using is broken or the video card using the slot has some form of problem.
    So, give a CMOS reset a try and see how it turns out.
  • Peter Steiert
    What are you trying to configure? Are you trying to tell the motherboard that your primary graphics device is seated in a PCI slot or are you attempting to do something else?
  • 13,433 Answers
Hey,
1 long 2 short is video card failure.
if you had a pci slot card inserted in the agp slot and you powered on, the motherboard may be damaged.
Posted on Feb 18, 2009
Compatible video cards for mainboard D1534
i assume by normal you're referring to PCI, you can't install a pci card in an agp slot. i'm sure you probably have a free pci slot. install the card in the correct slot and then when the system loads go into bios and select the correct configuration for video.
Apr 26, 2012 | Fujitsu Siemens SCENIC E600 PC Desktop
I have a Dell dimension 4300 running Windows XP SP3. The system has 1 Gb of RAM. I removed the AGP graphics card that came with the system and installed the VisionTek Radeon 256M X1300DMSPCI card into a...
Yes, it is compatible, just that you must first uninstall the previous video driver, then configure the BIOS to route the video signal to the PCI and not the AGP and only then install the new card. And in the end it will behave worse than the previous AGP card you got because the PCI interface is way slower than the AGP.
Just buy a good AGP card, PCI cards are made for office pc's in which the onboard one is totally obsolete.
Feb 08, 2011 | VisionTek RADEON X1300 , Graphic Card
Anybody know how to enable the AGP slot on an IBM NetVista 8305? Thanks.
1.
Shut down your computer and reboot to the BIOS. Reach the BIOS by pressing the Access IBM button on your keyboard or by pressing the F11 key.
2.
Use the arrow keys to scroll though the options to locate the video VGA graphic chip set. Follow the onscreen instructions to save the new BIOS settings.
3.
Turn off the machine after the BIOS settings have been saved. Unplug the power cord from the electrical socket.
4.
Open the side access panel of the Net Vista. On some models the panel will slide off; on others you may have to loosen the two thumbscrews holding it in place. If you have a desktop configuration instead of a tower, slide the top cover off the machine.
5.
Remove the existing AGP graphics card from the machine. You may need to use a screwdriver to remove the screw holding the card in place.
6.
Locate the proper slot for the new card. The new card may use the same AGP slot or use a PCI slot. If necessary, remove the dust cover for the selected slot with a screwdriver.
7.
Slide the new card into the slot. Screw the holding screw into place if the card requires one.
8.
Plug your monitor into the connection on the card. Plug the machine into the power source and turn the Net Vista on. Follow the onscreen instructions for installing the proper drivers if needed by your operating system. Replace the side panel when everything is working properly
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 21, 2010 | IBM NetVista 8305 PC Desktop
Anyway to connect an agp graphics card in a pci/pci express slot
The AGP bus works with a higher frequency, using 66 Mhz instead of 33 Mhz, and uses 64 bits instead of 32 bits. There is no simple way to use an AGP device on a PCI slot, and adapters are not normally available for sale.
May 04, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Converting from agp to pci screen does not load
If the original configuration was an integrated graphics setup, then the BIOS needs to be changed to AGP or PCI slot.
Nov 17, 2008 | Computers & Internet
PCI video slot changed to AGP video slot
First, install the AGP card in the AGP slot. Plug the monitor into the new video card.
Second, power up and press the F2 key to enter Bios.
The system should default to VGA but through the new and only video card available. If this works you will be able to save the settings and exit. It will reboot as normal. When prompted use the cd for that card to load the drivers.
AGP was a short lived concept and aren't that many to chose from.
If you don't get any video at all, the problem may lie in the motherboard and not really repairable.
Good luck.
Jun 02, 2008 | E-Machines Computers & Internet
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
May 11, 2008 | ASUS P5PE-VM Motherboard
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
AGP 8x not supported
Just a thought, but have you tried going into the bios setup and setting bios to system defaults or safe setting, saving and rebooting?
Dec 25, 2007 | ASUS P4S800D-X Motherboard
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
105 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
