Question about Maytag PYE2300AY Electric Dryer
Maytag gas dryer will not heat. What part do I replace and how do I replace it (step by step)
  • 547 Answers
Change heating coil its simple you streach it out from where you get it from open dryer from back
Posted on Feb 18, 2009
How to replace heating element on a Maytag dryer, model # HYG3658AWW?
its a pain .....are we talking about the hot surface ignightor due to the fact you have a gas model... please clarify and I will walk you through the steps
Mar 06, 2011 | Maytag HYG3658AW Gas Dryer
My Maytag Neptune MDG5500AW Gas Dryer heats up for a few minutes then stops heating. any ideas? thanks!
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
You will also find videos of disassembling most style dryers at the same site.
Nov 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag gas dryer won't heat. I have replaced the gas solenoids, If I tap the gas valve it lights. Old solenoids check out with correct ohms.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Nov 11, 2010 | Maytag MDG2600BWW Gas Dryer
No heat Maytag model MDG9316AWW. How do I replace
Below is an exploded parts diagram.
Below is your service and repair manual, all information diagrams etc are inside. It shows you step by step.
Jun 07, 2010 | Dryers
No longer have heat but everything else works
you may want to check your ignmitor here
since this is the first step of the gas heat cycle
beyond that if your getting any heat at all my next step would be to check the coils on the safety vave
both are easy repairs
Oct 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag gas dryer will not heat up.
The most common cause for "No Heat" on GAS dryers is bad gas valve coils. Go here for more: Dryer Repair Help
Go here for Maytag Dryer Part Info:
Feb 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
215 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
