Question about Maxtor Storage Plus (H01R500) 500 GB Network Hard Drive
I plugged another power supply, somewhat more powerful, and my maxtor came on for a split second before turning off... now with the original adapter it does not switch on.. please HELPP!!!??
  • 13,433 Answers
Hey,
the circuit inside is damaged becouse of overvoltage. the hard drive inside may still be ok. You could remove the hard drive from the case and plug it in to a computer directly to see if it works.
Posted on Feb 18, 2009
Dns-323 automatically shutdown few seconds after startup
had you found a solution ? i'm front the same problem :(
Aug 01, 2010 | D-Link Dns 323 2-Bay Network Storage...
Codigo sc546 aficio 1035 ricoh
SC546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Dec 11, 2009 | G-Technology WWD-91500101 G Speed 1500GB...
My hard drive was knocked of the table and landed on carpet
Computers do not like being dropped especially when it is powered up and running. It can do a heaps of damage.
If the hard drive in the computer makes a clicking sound and it won't boot up and/or an error message says it cannot find the hard disk or operating system, then the hard disk is damaged beyound repair.
With luck if the hard disk is only damaged then you can replace the hard drive and install Windows on the new hard drive with the device drivers and your programs. Your data on the old hard drive is gone unless you backed up your data onto CD, flash drive etc.
Sep 29, 2009 | Maxtor Fusion 500GB External Ethernet...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Exactly the same problem with LaCie NAS becoming unresponsive
Mine used to do that too.
It's working much better since I repaired the power supply.
The power supply shipped with the disk is really bad and dies in less than one year. I had to replace mine 3 times !
I'm now using a power supply I repaired by replacing the 5 capacities and it's working fine.
I hope that will help.
Aug 16, 2009 | LaCie Ethernet Disk (300788) 1000 GB...
I dropped my external hard drive, not even a foot, now when i plug it, it just keeps on loading or beeping every 5 seconds.
The power connection to the drive is damaged. The drive is not getting enough power to spin the drive properly so it is beeping. Check the power cord and/or the USB cable for damage as well.
Aug 14, 2009 | Iomega Computers & Internet
Computer doesn't recognize drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Jul 11, 2009 | SimpleTech SimpleShare 250 GB Network Hard...
Freecom external hard drive classic 2.5
Hello
Kind Regards
Andrea
Dec 25, 2008 | Freecom (24358) 160 GB Network Hard Drive
Boot problems
Try with another computer if the problem persist then the problem with your HDD PCB(printed circuit board). go to nearer harddisk repair centre ASAP. Thanks Arun
Feb 11, 2007 | Maxtor Storage Plus (H01R500) 500 GB...
Maxtor Storage Plus (H01R500) 500 GB Network Hard Drive Logo
130 people viewed this question
Top Maxtor Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Rick Arnold
Mark Taylor
Mark Taylor
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
