Question about Sony Playstation 3 (PS3) Console
Cannot get internet connection on wireless
When I go to the access point page. Say for instance, I pick the 100% signal. How do I go about getting the SSID, or name from that person who setup for that particular access point.
  • 265 Answers
Well you cant, as its not your own connection, unless you ask ther person for there WEP access code.
Hope this helps
Posted on Feb 18, 2009
Server not found wireless
This may be a signal strength issue. It may be necessary to install and extension cable for the antenna, or a signal booster midway between the wireless access point and the computer, or maybe both.
It all depends on how far away the computer is from the access point, and how many walls it has to pass thru. The thickness of the walls changes if the walls to deal with are at an angle to the computer or perpendicular (90 degrees). This makes the wall thicker if it is at angles between the PC and the wireless access point.
If at all possible, moving the wireless router closer to the PC, will help, as will moving the PC closer to the wireless router. This solution will solve the problem without much added cost. Also, moving the PC is probably easier, because it IS wireless. If this is unacceptable because of location, or surrounding shelves, etc., then a wireless repeater will be necessary. YOu will need to get help from someone who understands wireless installations, as it can be tricky in some instances to place it where it will do the most good. It may cost $100 or more for this device.
Oct 05, 2013 | TP-LINK Computers & Internet
I want to connect my HD TV to the internet, wirelessly thro my home network. I have purchased an access point (Linksys WAP610N) but that doesn't appear to support my application. Should I be using a...
An access point is used to extend the signal.
Have you set it up by putting the MAC address of the WAP into the router and vsetting it up as a repeater?
Watvh this video:
http://www.youtube.com/watch?v=0I6vKp_XuSQ
After you setup the WAP correctly, the TV should pick up the signal.
Jul 02, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
I recently restored my Compaq Presario V2000 back to windows xp (it was vista before). Now, I cannot connect to the internet. The laptop picks up the signal and the icon on the bottom right says that...
A Belkin router doesn't usually force the utilities page on you. I would advise checking your start page - you might have set it to your router's homepage by accident.
Aug 19, 2010 | Belkin N1 Wireless-N Wireless Router
Setting up an access point to have same settings as the router?
It seems like it is the issue with the router's firmware. Upgrade or reflash the router's firmware. This will definately solve the issue
Jul 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My Linksys Wireless A P only allows one computer to connect
You need to get a router in order to share the Internet connection. The existing Internet connection (from the DSL/cable modem for instance) goes into the WAN port of the router/firewall, then you connect the AP to one of the LAN ports.
Today it is often a better idea to buy a wireless router instead, i.e a router with built-in wireless AP. They are very inexpensive.
May 28, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Variable wireless performance
what this looks like is a case of intermittent signal
call ur ISP have them run a line test
if you have purchesed a service that is better than the basic
what could be happening is that the line capacity is to high
(trying to push 100 gal. of H2O in a 1 IN. pipe in 1 sec. cant happen
i work for att. tech. support and sometimes incrising ur speed package will make ur internet sluggish
most routers dont go bad i belive its a line issue
good luck , July
rate me please
Apr 11, 2009 | NetGear WGR614 Wireless Router
Can't configure router so my adapter can access my network
Use the XP to config Router.
Your 98 and your router are on different SUBNET check it.
Connect XP computer to Router using lan cable
Be sure to be on same subnet
Configure your Router
SEt same subnet for every PC connected to router.
Then connect to router using Wlan.
Feb 04, 2009 | Dynex Enhanced-G Wireless Broadband Router
3Com 7760 (3CRWE776075US) 802.11a/b/g...
Hi there
I think up to now you've been using someone else's Internet service, by picking up the signal wirelessly. You need your own Internet Service. You now connect your access point in the way the Internet Service Provider guide you. It is a different set up with cable (they provide a modem) or with BT (connection through your phone line).
Dec 31, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Have just bought a computer second hand and have just got internet running with 100% signal but cannot connect because we cannot find local area connection to access files
As dragoness1 says, you don't need a LAN to connect. Right click wireless icon in system tray (bottom right of screen), select "show available Wireless networks". Select one and click connect. If they're not from your own Internet service, they may be protected by a password.
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
Keep getting 800 error stating network error and it disconnects. ps3 is 2 feet from access point, 100% signal and I have reset modem twice and have a signal booster in the house?
If you are using wireless connection that could be your problem. Wireless isnt to stable for connection, but it depends on your environment(where you live). You could have a slow internet connection in your environment.
Aug 02, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
