Question about Emerson EWV403 VHS VCR
VCR will not record with new digital cable box
I recently switched from analog cable to digital cable. A digital box was installed and now my VCR will not record. The digital box has to be on channel 4 and my VCR has to be on channel 3. My cable comes in thru the digital and the into the VCR. Is there anyway to correct this. There is no switch in the back of the VCR to change the channel. Thanks
  • Jenn Ellis May 11, 2010
    OK. Are you saying that if you only had a digital box, the TV connected to it would have to be tuned to Channel 4? And if you used only a VCR, the TV connected to the VCR would have to be tuned to Channel 3?
    If that is the case, then set the VCR's own TV-channel tuner to Channel 4 and your TV's tuner to Channel 3. Let me know if this works. I have a similar setup and it does work, once you get the settings right.
    I am assuming that the digital cable box is connected to the VCR via a regular coaxial cable, like the one that comes out of the wall. If you are using some other cable, the settings on the VCR will have to be adjusted.
  • My reply is May 11, 2010
    Is your VCR connected to the digital box via a scart cable?
    Problem Solver:
  • 13 Answers
The short and simple solution is to tune the VCR to the channel that the cable box is set to (4), and then tune teh TV to the VCR's output channel (3). If you do this you should be able to see the Cable channel through the VCR tuner and then record. Any other solution would require figuring out how to set both the VCR and the cable box to the same channel, but it sounds as if you have ruled out any possibility of being able to do that.
Posted on May 11, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Posted on Mar 01, 2010
  • 87 Answers
SOURCE: Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Posted on Jun 18, 2009
  • 16 Answers
SOURCE: VCR won't record
Hi Pat and Mary Jo,
It sounds like your VCR might be trying to record your line input instead of the TV channels and would explain a completely black recording.
The line input is where would connect a camcorder or another VCR, where you would play on one machine and record on your VCR.
Some models have a slide switch on the front that selects the input. Others let you select it from a menu option. Still others automatically select it when the appropriate cables are inserted into the line in connectors.
Let me know if that was it or not. Thanks,
-Vince
Posted on Oct 03, 2008
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I HAVE AN OLDER VCR,AND I CAN NOT RECORD CHANNEL 12,WHICH HAS SWITCHED FROM ANALOG! I MAY NOT BE ABLE TO RECORD EPRIOD!
Unfortunately, no. The VCR only has the older analog tuner and can't get digital channels. You'd need a converter box connected to the VCR for those.
Apr 12, 2009 | Televison & Video
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Analog VCR
no you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Jan 23, 2009 | Memorex MT1134 13" TV
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Emerson EWV403 VHS VCR Logo
1,538 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
