Question about Onkyo TX-NR905 Receiver
Onkyo TX-NR905 Firmware updates
Do you recommend to upgrade the firmware from 1.01 to 1.08 on the Onkyo TX-NR905? Onkyo said to upgrade only if I am having issues with the unit. Also what improvement will the new firmware update have on the receiver?
  • 979 Answers
SOURCE: Gold version Onkyo Tx875 amp
What country did these units come from? Video specs are different in various places in the world. NZ uses a format called "PAL", then there is "SECAM", used in some parts of Europe, (most notably France) and then there is NTSC, used in Japan, US and S. Aisia. Also, I need to know you video source and format...accordianman
Posted on May 01, 2008
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
SOURCE: No Video only sound with Onkyo TX-SR605 7.1, tried everything, HELP!!!!
same receiver same problem. at least ou're not alone.
Posted on Feb 24, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
  • 4 Answers
SOURCE: I have an Onkyo TX-SR606 connected via hdmi to a
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Posted on Jul 31, 2010
Have a Onkyo TX-RZ710. Fail to do firmware update. Try to do using USB, now Recovery:NET display. Dont know what to do?
Hello, I am sorry for your issue. The update may have stopped due to a power loss or another reason. The receiver needs to be sent to a service center. I have included a link below to search for a center. Thank you, Onkyo USA.
http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Mar 19, 2017 | Onkyo Audio Players & Recorders
My onkyo tx-nr5007 wont give me the option for firmware updates. it wont give me a picture on my t.v so i cant adjust anything that way. what can i do? how do i know if my hdmi board is no good?
Greetings
The DSP HDMI board is not accessible anymore .
ONKYO has this problem for some time now
while upgrading over the Ethernet, the system doesn't recognize the new software.
And the AVR stops responding.
At the moment am working on it .
hope for the best .
Jun 11, 2016 | Onkyo Tx-nr5007 145 Watts 9.2-channel Av...
Do I need a firmware update to decode DTS:X Blurays? If so, when can I expect Onkyo to upgrade?
Hi Tony, DTS:X will be available via a Firmware update as soon as it is released by DTS:X, we will advise you via our webpage at onkyousa.com, Thanks, JT
Jan 06, 2016 | Onkyo Audio Players & Recorders
DISPLAY STAYS WITH THE ONKYO DISPLAY AND THATS IT
The video card to your Onkyo is OK, as it displays the Onkyo Logo. Contact the authorized service center for Onkyo. A firmware update is necessary. With a Corrupted firmware, this kind of display effects can occur. Gopakumar Gopalan Google
Feb 28, 2014 | Onkyo TX-NR905 Receiver
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
My tx-nr905 recievers output audio goes out when connected to my projector and a dvd player, but its ok with any other output combo; proj/sat or tv/dvd or tv/sat etc..... bought new about 4 yrs ago, has...
Semantics maybe, but sources are INputs. OUTputs are speakers, audio to other devices.
A DVD is always an INPUT.
So what's different? IOW, how are the DVD and Projector (Really? It uses a video OUTput) connected for audio? Have you looked at the manuals? Digital sources must be assigned, for example.
Aug 25, 2011 | Onkyo TX-NR905 Receiver
No sound from front channels under all sound modes. All wiring looks to be in tact.
Check to see if the speakers "A" are selected.
Look in the upper left corner of the display screen for something that says a or b. Let me know what it says.
See the manual here @ page 11 box 3 for more info.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-nr905_manual_e.pdf
Nov 22, 2009 | Onkyo TX-NR905 Receiver
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
Keep us posted,
Dan
Jul 28, 2008 | Onkyo TX-NR905 Receiver
Onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Nov 15, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-NR905 Receiver Logo
2,214 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
