Question about Emerson MW8107WA Microwave Oven
Sanyo Microwave manufactured in 1993. Need model/watts info.
I cannot find the watts nor the model number of this microwave oven manufactured by Sanyo in September of 1993. I have the serial number. Any suggestions?
SOURCE: ihave high-pointe microwave oven serial
I also have a High Pointe Microwave Model EM925BSC SN 0608MO3508 manufactured in Aug 06. Tried to use it for the first time this weekend after buying a new Honda EU2000I to use it. The turntable does not turn automatically or when I try to turn it manually. Cooks OK. Nothing in the owner's manual that came with trailer (Zoom 178) mention how to fix the problem.
Anyone have a Ph# for High Pointe. Their Service center address is High Pointe, 2617 N Great Southwest Parkway, #100 , Grand Prarie, TX 75050.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: my microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Posted on Jun 05, 2009
likha
  • 790 Answers
SOURCE: How many watts on my microwave?
Hi
The wattages of your microwave is 800 watts.
Thanks!
Posted on Jun 15, 2009
User manual
Call the company who manufactures your a Sanyo Convection and ask them to send you a user manual guide. Make sure you give them the grill model number.
Apr 11, 2014 | Sanyo EM-G2585W Microwave Oven
What's your problem? the microwave buttons are locked
some units have a child safety button lock feature.. You may have to look into your owners manual or look up the info on the manufacturers website for info?
Nov 06, 2012 | Belling STW25 900 Watts Microwave Oven
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993.
Partstore.com has the owner's manual for sale: http://www.partstore.com/Model/Matsushita/Panasonic/NN2909.aspx ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. http://www.partstore.com/Part/Matsushita/Panasonic/NN2909/Matsushita/Panasonic/OMNN2909/New.aspx is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
May 28, 2011 | Smeg FMC24 850 Watts Convection /...
I need an operating manual for Siemens HF87951 800 Watts Microwave Oven
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 12, 2011 | Siemens HF87951 800 Watts Microwave Oven
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
Mar 01, 2011 | Kenmore 80492 / 80494 / 80499 1000 Watts...
Microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Jul 10, 2010 | GE JES735WJ Microwave Oven
What is Sharp R-254 800 Watts Microwave Oven??!?!?!?!?!?!?!?
Sharp represents the Manufactures.. R-254 is the Model no. and 800 Watts represents the output power of the microwave.
Jun 09, 2010 | Sharp R-254 Microwave Oven
Emerson MW8107WA Microwave Oven Logo
71 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
