Question about Frigidaire Microwave Ovens
MVH1190E built in Frigidaire microwave loud pop when turned on repairable? Where?
  • 579 Answers
SOURCE: Frigidaire Microwave will not heat and is a little louder than usual.
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 11, 2008
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Posted on Sep 08, 2009
bulldogchief
  • 388 Answers
SOURCE: microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Posted on Sep 14, 2009
  • 572 Answers
SOURCE: my frigidaire GLMV 169D 1000 watt microwave made a
the magnetron. is what heats
Posted on Feb 11, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
I have a FMT116E1W made a loud pop and now no power or anything.
This sounds like the magnetron has failed, the pop sound is a classic sysmptom.
May 18, 2012 | KitchenAid KHHS179LSS Convection /...
Frigidaire PLMB209DCB 1200W Microwave. Mfg 2005. Started sparking and loud popping. Scorched cardboard covering. Worth looking at to repair?
No, Your better off buying a new one. Sounds like the Magnetron is acting up and that is the most important and dangerous piece of hardware in the Microwave.
Jun 08, 2011 | Frigidaire GLMV169 Microwave Oven
My 3 year old frigidaire microwave made a loud pop and stopped heating. Everything else works. It also now makes a loud humming sound while running.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101 ][
\=-0-]
Apr 02, 2011 | Frigidaire GLMV169D Microwave Oven
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
Loud pop and microwave doesn't heat anymore
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave made loud popping sound and now does not heat.
Hey,
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
I was boiling water on the electric range beneath my FRIGIDAIRE FMV157GC 1.5 Cu. Ft. Microwave Oven when there was a loud snapping/popping noise occured. I immediately shut off the microwave and thought...
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Sep 04, 2008 | Frigidaire Microwave Ovens
Popping and shooting sparks
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
187 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
