Question about Poulan Pro Chain Saw 46cc 20"
I have a cub cadet commercial chainsaw that seems to be flooding out when I give it gas. The saw was running fine and just started running rough. Does anyone have a helpful solution to this problem? I already put a new spark plug in it. Thanks
  • Anonymous Mar 28, 2014
    gas line replacement
2 possable solutions one some of the carb adjustment screws on those start to shimy easy fix but the there is only one tool for those carbs it's 10-12 dollars a peice or 2 you have a slight crack in the intake line allowing extra fuel into the carb chamber. i'd check the carb adjustment though my two ran fantastic at factory setting till after about 50 hours then they liked to run with a little more air.
Posted on Mar 14, 2009
  • 201 Answers
Have you cleaned the air filter on it also?
Posted on Mar 04, 2009
I have a cub cadet commercial 42 in cut 14.0 kawasaki FC420V it will start fine idles for 20 sec then dies
sounds fuel related Mike, it is starving for fuel check everything with the fuel system. maybe rebuild the carburetor. kits are cheap.
Oct 02, 2016 | Cub Cadet Garden
Did you mean: i have a cub cadet 1040 ltx that is running rough and loud?
Head Gasket possibly
You should be able to find out where
the noise is coming from
Oct 11, 2014 | Cub Cadet Garden
Cub cadet with 24 hp kohler v twin that acts like it is flooding out after 20-30 min of mowing.stop mower and it picks back up,may mow 2 feet and start doing it again,seems to do it mainly when turning or...
It sounds to me that you have something in your gas tank that is intermittently plugging your gas feed hole. Inspect in your tank for something floating around in there and pull it out.
Apr 13, 2014 | Cub Cadet Garden
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
I 1050 will run fine for about three minutes and then cut off. When i restart the engine starts hunting and running rough. have replaced carb and fuel pump. cub cadet brand
sounds like the gas is bad, drain tank, refill will known good gas. You may want to put a fuel cleaner in with the gas, if you let equipment sit around for awhile with gas in it it will tarnish and draw moisture. Hope this helps Tim
Apr 19, 2011 | Garden
Cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
May 10, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
120 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
