Question about HP OfficeJet 6110 All-In-One InkJet Printer
Set up fax and dsl using one phone line
How do i set up my fax and dsl using the same phone line. i have a single dsl filter, and i keep having to unplug the phone line and plug in the fax to send a fax. since the fax isn't always plugged in, i can't receive faxes. someone mentioned a double dsl filter. can i go buy a second single dsl filter? where do all the lines go?
thanks!
    Problem Solver:
  • 5 Answers
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
Posted on Feb 21, 2009
Can canon mf4370 fax on dsl line
Fax machine operation can be interrupted by DSL lines, however, because the DSL signal is also transmitted through phone wiring. This can result in a loss of data in the fax if steps are not taken to prevent it. Fortunately, this is not a difficult thing to fix.
Items you will need
  • DSL filter
Step 1
Unplug the fax machine from the phone jack.
Step 2
Plug your DSL filter into the phone jack. DSL filters are specifically designed to eliminate interference from the DSL line on your phone line.
Step 3
Plug the fax machine into the phone line jack on the DSL filter. You can now use your fax machine and DSL line at the same time without risk of data loss or interference.
Feb 05, 2013 | Canon ImageCLASS MF4370dn Laser All-in-One...
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
I have a new AT&T DECT6.0 single line answering machine and i'm trying to connect it to my Epson Aculaser fax ( the single phone line is phone/fax), however it's not differentiating the...
If this is a new machine, why haven't you contacted AT&T? Sounds like either it's a configuration problem in the answering machine or it's incompatible with your phone line.
Jul 17, 2011 | Epson ACULASER CX11NF All-In-One Printer
No one seems to know how to get the HP C6180 All in one FAX to work after it gives the error message UNABLE TO SEND OR RECEIVE FAXES, Press OK. Someone at HP surely has an answer to this problem. It...
The first thing I can suggest is you connect the unit to a known working regular unshared/non dsl phone line.
Check for dial tone.. if you get one.. place the unit in auto answer and call it using a cell phone etc.
If that works.. send a test fax.. at least you will know if the unit functions as designed.. chances are it will.
You do not mention if your DSL is via a Splitter (usually at the NID box) or filter.. or both however it sounds like a filter. A lot depends on how your phone outlets are wired.. if they are Daisy Chained.. you need to check every single filter and every single wall plate connection.. There are three basic wire routing techniques.. also known as Topology.. without knowing your style it is hard to diagnose.. regardless..
Some faxes are more likely to fail to any type of line "noise" than others.
You may need to replace the splitter.. or filter(s) or both..
I have seen broken wires behind the wall plate and even at the NID box on the side of the house. Often these wires appear connected until you examine them closely.
Again.. if you are not sure how the place is wired every jack should be tested. Even had lightning burn a needle sized hole in the phone line once causing a lot of line noise.. especially when it rained.
Disconnect the modem from the line and try the fax.. if it works.. you may have a faulty modem or a leaky port.. so to speak.. which would introduce line noise or interference to the voice line.
Finally as simple as this sounds.. check all he settings on the fax machine.. especially the tone/pulse setting. Obviously it should be set to tone.. these settings should not have changed.. but if it lost power.. worth checking.
Your problem is more than likely a DSL equipment related issue or a termninal connection issue then a fax machine problem.
Best of luck to you
Feb 24, 2011 | HP Photosmart C6100 All-In-One Printer
I have a Cannon MX310 printer, fax , copier. I cannot receive faxes. Can it have something to do with the fact that I have digital phone service, what setting does it need to work.
You might try a DSL phone filter to eliminate extraneous noise on the digital line. My digital phone line had constant, repetitave clicking noise until I installed a DSL filter. Have you tried calling your fax number from a cell phone to see if there is noise on the line and or if the fax will pick up?
Oct 31, 2009 | Canon Office Equipment & Supplies
I've changed my internet providers and have gone from a cable internet svc to a dsl phone line provider. Now my computer fax machine says it is offline. Is there a setting that I need to change?
Most likely cause is you don't have a dsl filter on your fax line. Without the filter, your fax machine's modem can't discern between a dsl signal and a telephone signal Since the telephone line coming into the building is now carrying a dsl signal, a filter is necessary to receive/send faxes.
Aug 25, 2009 | Office Equipment & Supplies
Fax set up -I've used this model for years and now
do you have dsl filters installed? the fax should go to unfiltered line not the filtered dsl line.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Toshiba e studio 50f problem with driver software
U need to make sure the phone line is working. Hook a single line phone to the line, and hear whether tone is available, notices also is there any noise on the tone, this may affect the line condition.
Make sure u plug the phone line to the "LINE" port.
If no tone on the line, then u need to check with the telco...
Nov 21, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
777 people viewed this question
Seeker5211
Seeker5211
