Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wf640 showing f-07 error code what is this problem and any ideas how to solve it
  • Anonymous Feb 22, 2009
    Ditto F-07 error on my WF64, just happened to me. People are saying that this is the heater element relay, and it has to be changed with the main PC board. Im a looking
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
It's the heater relay stuck. you will need a new power board. and heater.
Posted on Feb 28, 2009
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
Is there any filtter to clean in hotpoint wf640
Remove the lower rear panel of washer, locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Reassemble and test for leaks.
Have some cloths ready to wipe up water from hose.
Jan 10, 2011 | Hotpoint Aquarius WD640 Front Load...
I have washing machine Aquarius wf640 + it keeps showing f-02
F02 indicates that the motor tacho has broken or become detached, this is to be found on the end of the motor shaft.
Pleawse rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test light
Press and hold "on/off" and "start" buttons together for five seconds.
Apr 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
680 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
