Question about IBM ThinkPad R50e Notebook
Laptop Battery Not Charging
I have an IBM Thinkpad R50e
having problem since few days that while being plugged in AC, battery does not charge. charging is decreasing but not increasing. right now it is at 16% and still decreasing when unlpugged from AC. but dont increase. can any body help me ? what is problem
  • arehman_chd Feb 19, 2009
    thanks alot Bro for your kind advice. i just want to ask one thing, when AC adapter is Plugged in, Laptop works normal on it. I mean either remove battery or not while plugged in AC, Laptop still works normally as it work on AC Adapter. So still it would be Adapters problem or battery problem ?
    thanks
  • muadim Mar 21, 2009
    same,but the bios is affected- it's data are lost when unplugged from power.
    Battery is new,also the power adapter is new .
    President:
  • 2,110 Answers
First try in other power socket if it works then you have to replace the power adapter...
Posted on Feb 18, 2009
  • Sibananda Jena
    Sibananda Jena Feb 19, 2009
    then in that case your battery has some problem..
IBM Thinkpad X60- Charging LED ( Amber) flashes continuosly- battery NOT charging
An incompatible charger could be doing this, as could a failed battery charging circuit in the notebook. It is also possible that the battery is no longer capable of accepting a charge. The universal charger must be able to provide the same voltage as the original charger and have an equal or higher rating for wattage or current.
Feb 08, 2013 | IBM ThinkPad X60 1706 Laptop Universal AC...
Bought a new battery (larger one) and it will only charge for 1 second?
Check if the battery is already fully charged. If it is, the charger will stop charging when battery is 100% charged.
You can check this by unplugging the charger cord from the laptop. If the battery is not fully charged, plug in the charger cord into the laptop again, start the computer and enter the BIOS. In the BIOS, look to see if you have a "battery check" and start it. This will test the charging and discharging cycles of the battery.
Mar 22, 2010 | IBM ThinkPad R50e Notebook
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
IBM R50e thinkpad - where is the reset button?
keep your power button pressed for 3-5 seconds to reset.
let us know the results, thnx
Jan 30, 2009 | IBM ThinkPad R50e Notebook
Battery indicator on even after turn off the laptop
Reset the battery.....remove battery from system...boot while your adapter is plugged on....shut down..reinstall the battery......
if this doesn't help..
go to Control Panel>>>>>>Power Options and view setting ..........what does the system do after being switched off options
keep me posted
Cheers
Nov 17, 2008 | IBM ThinkPad T40 2373 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
Thinkpad R50 Reboot problem
Try a different battery. Then come back.
Jun 23, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad R50e PC Notebook not working
the foam must have caused a shortcircuit on the board
May 08, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad R50e Notebook Logo
564 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
