Question about Saeco Vienna Espresso Machine
Saeco Vienna leaks water from water tank
I am having water leak from the water tank. The tank is not cracked but doesn't seem to create an adequate seal when seated on unit. I have tried reseating the tank many times but still have water leaking down the back of the unit.
    Problem Solver:
  • 8 Answers
Sorry for the delay in response but I just read your complaint. I had similar water leakage issues and mistakenly replaced a bunch of stuff without stopping the leaks, until I discovered the real problem; the O ring seal that the water reservoir sits in located under the reservoir where it mates with the machine. Easy to replace and cheap. No leakage problems since I both replaced the O ring and started the routine of not taking off the water reservoir to fill it, but leaving it in place and filling it from a bottle. That technique does not any wear at all on the seal ring and so it won't leak in the future.
The item is called a "Saeco-water inlet valve gasket" , has a part number of NM05.006 and costs $7.50. I purchased it from Services Unlimited located at 650 N. Cannon Ave. WH-305, Lansdale PA 19446; phone 215-361-7000 Fax 215-361-7434, e mail granita@rcn.com but you can find it at any authorized dealer, I am sure. I ordered two and with shipping the cost came to $21.50.
You can request a fax with a parts diagram and listing, which I found most helpful in diagnosing issues and see where stuff goes..
Hope this helps you..
George W Conrad
Posted on May 04, 2009
  • F Morgan Nov 02, 2010
    I've got an easier fix than that. My Saeco was leaking around the tank. After I read this I went looking for the "O" ring. Couldn't find the "O" ring ...but did notice a coffee bean in one of the little holes that the plastic legs fit into. It was in the perfect place to barely keep the tank raised while engaging the open water valve. "O" ring $7.50...finding a bean was the problem...priceless!!!
    I've got an easier fix than that. My Saeco was leaking around the tank. I read this about the "O" ring...and it DID help! I couldn't find the "O" ring BUT I did find a coffee bean in one of the holes that the little plastic leg sits in. It was keeping the tank raised just enough to flood the water out of the pressed valve. "O" ring...$7.50...finding a coffee bean and digging it out...priceless.
  • 3 Answers
Make sure to not over-fill. There is a notch cut into the water tank lower than the rim. I went through the same thing until I noticed this notch.
Posted on Apr 10, 2009
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
2,049 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
