Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Hitachi 51F500 Cleaning
I just got a 5 yeear old 51F500 and would like to clean the projector lenses and back side of the screen.  How do I get at them.  I opened the lower back half and blew it out, but see no way to get at the back side of the screen or projector.  Does the screen come off?  Also I am very good with electronics.  Is there some settings other than what is in the onscreen menu I can do to clean up the image?
Thanks
a
To clean:
1) Remove front bottom cover - pull outward
2) Remove 8 screws at bottom of screen, slide screen upward to remove
Do not touch any of the electrical components, they can store energy and are also sensitive to static.
3) Clean inside of screen with light cleaner
4) Dry clean lenses with non-abrasive DRY cloth - no cleaners
5) Vacuum any remaining dust or cobwebs inside cabinet
6) Install screen and trim and "test" it for a bit
Posted on May 05, 2012
    Genius:
  • 2,920 Answers
The trim on the screen pops off and behind that trim are screws that hold the screen in place...once you remove the screen you can clean the lenses and the mirror and maybe get a cleaner clearer image
Posted on Feb 18, 2009
How do I clean the inside of the lens on my wonderwall 1625073 projector
It is recommended only cleaning the outside of most projector lenses. However if obstructions have worked their way into the case and will not leave the lens, you may be able to remove the bulb (carefully, following the manuals instructions for bulb replacement)
And gently spray inside towards the lens where the bulb was. However, keep in mind the display itself sits between the bulb and the lenses,
Some projectors have air fins along the sides of the lens, some air in these fins can also loosen debris away from the lens.
Ensure the front of the lens is not dirty and that the focus has been properly adjusted before cleaning the back of the lens.
Nov 28, 2014 | Office Equipment & Supplies
Cleaning lenses on projection tv
Have the set unplugged please.
CAN BE DONE FROM REAR--from the front is a bit tricky and dangerous---from rear with rear cover removed locate the three large black lens( hard to miss them) and clean them with a lens cloth or a paper towel with glass cleaner sprayed on it.
Depending on how much dust===should be done one time a year.
Apr 28, 2012 | Hitachi 51F500 51" Rear Projection...
My Hitachi TV is showing a double vision on the lefthand side of the screen.
Your projection lenses are probably covered in dust. My TV did the same thing with the blue color on the right side. Usually you can get to the projectors from the bottom front or back. Goo luck.
Mar 10, 2010 | Hitachi Televison & Video
What is the life expectancy of the Hitachi 51F500
5-10YEARS. THAT TV SOLD FRO 999.00 AT ITS END RUN SO YOU MIGHT WANT TO THINK ABOUT REPLACING IT
May 21, 2009 | Hitachi 51F500 51" Rear Projection...
I have a double picture on my 6 year old Hitachi Projection tv.
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Dec 11, 2008 | Hitachi 51F500 51" Rear Projection...
Cleaning projectors
You dont it is a specialist job please take it to an autherised service center, it has high level UV from when turned on with covers removed do not risk it, as it can blind you.
Marc-Engineer
Jun 23, 2008 | Hitachi 50FX20B 50" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Red dots on screen of
Typically this is an indication of dirt in the optical path. Try blowing out the area using compressed air. Also, make sure that the lens is clean. Use a cloth and solution made specifically for cleaning lenses.
Dan
May 05, 2008 | Televison & Video
51F59A
TV: Viewing Screen RPTV - damage and maintenance
http://www.hdtvmagazine.com/forum/viewtopic.php?t=6547
Mar 21, 2008 | Hitachi 51F500 51" Rear Projection...
"burn in"
The burn in can't be fixed cheaply.You would have to replace the burnt crt guns.The screen can be removed for cleaning.behind the speaker grill are several screws right below the screen.Remove them and slide the whole screen assembly upward.
Mar 05, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
296 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
