Question about Dishwashers
Water wil not exit dishwasher - Dishwashers
  • 547 Answers
Clog in drain line
Posted on Feb 18, 2009
Have a bosch dishwasher Mod. No. SGI53A55AUSS installed March 2004. All filters clear, exit pump clear and working. Switch on washer can hear exit pump working but machine does not accept water to fill....
You said you had water under the dishwasher,did you remove the lower panel below the door and check for water in the base frame as well. Bosch dishwashers have system in the base frame that detects water in base and cuts power off to every component except drain pump till it no longer sees the water in the base.
Hope this helps
Gene
Aug 03, 2011 | Bosch Dishwashers
Not all water drains, about 2 quarts left on bottom of dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
May 14, 2011 | Whirlpool Dishwashers
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
Smoke comes out of top right corner during wash .whirlpool dishwasher model # GU1200XTKQ0
This is most likely steam. To allow water to enter the machine, air needs to exit. It exits through this vent. As the machine heats the air inside expands and exits along with the steam from the hot water and you are seeing it come out through the vent. No wories they all do this. Have a safe day.
Oct 05, 2009 | Dishwashers
Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water will not drain out completely
You probably have a partial blockage in the drain line or the drain pump. This is not difficult to check. Just open up the panel below the door of the dishwasher and look for the flexible drain line. It is attached to the drain line pump. Unscrew the pump from the dishwasher frame, disconect the drain line and take a look at the pump and the drain hose. You may find a piece of glass or other hard object that is causing the problem. good luck.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Miele dishwasher g664 12 years old maybe?
Hi Lawrenceo,
I'm Harvey the Master Plumber.
You stated your problem as: the dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose.I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
It sounds like the pump has failed. The motor and the pump are two different parts. This is a common problem with older units. Frankly, after 12 years of use, at least you got your money's worth. At this age, to repair it is to throw good money after bad. It's time o replace it. You'll find there are much nicer models available now.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
No air gap device
If you are installing a dishwasher as a permanent appliance into cabinetry, drill a hole up near the top of the cabinet ( near the back) and route the drain house thru this hole over to your drain connection.. An air gap is formed by bring this hose up high and looping it down to the drain tie in.. This wil keep some water in the dishwasher below and act as a gas trap so no gases get into or out of the dishwasher.. If you are using a protable dishwasher.. by merely placing the drain hose ( that normally exits near the back/bottom of the dishwasher ) into a sink.. you have formed an air gap in the same manner.. as long as the drain hose is raised up and over a high point in the cabinet and doesn't allow back siphoning of water into the dishwasher.. you are all set.. Hope that helps..
Aug 30, 2008 | Dishwashers
DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
