Question about Palm Treo 650 Handheld
Need a phone reset
Phone is in system lockout i need to reset the whole phone
  • 26 Answers
Part 1
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
Never perform a hard reset unless a soft or warm reset does not solve your problem.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Posted on Feb 18, 2009
  • gsessons
    gsessons Feb 18, 2009
    Part 2
    Zero Out Reset
    On devices with non-volatile memory such as the Tungsten T5 and Treo 650,
    it's possible that a low level utility can still recover information
    from the device memory even after a hard reset. To ensure the device's
    memory is completely erased before you send it in for repairs, sell it,
    or otherwise pass it on to others, you should perform a Zero Out Reset.
    The hardware procedure is complex but works for both Tungsten T5 and Treo 650 and is documented here as 'Method Two': Resetting your device (zero out reset)
    The much simpler software procedure (Method One) only works for the
    Tungsten T5: simply ensure that you have assigned a password to the
    Tungsten T5 under Prefs, General, Security, and then do a Hard Reset as
    desrcribed above. This will automatically format the memory (i.e.
    perform a Zero Out Reset)
    Users of the Treo 650 must use the Method Two (the hardware procedure) if they want to perform a Zero Out Reset.
    Secure Erase
    On devices with hard disks such as the LifeDrive,
    you're provided two options during a hard reset: Quick Erase and Secure
    Erase. As it's possible that a third party can can still recover
    information from the disk after a Quick Erase, you should perform a
    Secure Erase to ensure the device's hard disk is completely erased
    before you send it in for repairs, sell it, or otherwise pass it on to
    others.
    A Quick Erase takes about five minutes, and a Secure Erase can take
    twenty minutes. Note that if your handheld has a password assigned, you
    are only provided the Secure Erase option.
    1. Slide the power switch to the right and hold it in that position.
    2. While
      holding the switch to the right, use the tip of the stylus (or a
      similar object without a sharp tip) to gently press and release the
      reset button on the bottom of your device.
    3. Wait for the reset screen to appear, and then release the power switch.
    4. On the reset screen, press Up to perform a Quick Erase, or Down to perform a Secure Erase.
    5. During
      the reset process, a status screen appears with the words "Quick Erase"
      or "Secure Erase" and a progress bar, followed by screens showing the
      palmOne, Palm Powered and LifeDrive logos.
    6. Then you will be
      prompted to tap the screen to align the digitizer and select the
      language you want to use on your device. A screen appears showing the
      palmOne logo and a progress bar.
    7. When the "Welcome: Setup your
      device" screen appears, the hard reset is complete. Follow the onscreen
      instructions to set up your device.
    FlashPro Reset
    On machines that have FlashPro (a third-party enhancement that provides
    user-access to free Flash memory) it is possible that moving a
    corrupted application into Flash will prevent the unit from responding
    to any of the three normal resets.
    The makers of FlashPro have provided for an additional reset procedure that will reformat your Flash memory.
    Never perform a FlashPro reset unless a hard reset does not solve your problem.
    To do a FlashPro reset:
    1. Hold down the memo/note button on the front panel of the handheld.
    2. While
      holding down the memo/note button, use the reset tip tool (or similar
    4. When the logo screen appears on the screen, release the memo/note button.
    5. When
      the 'FlashPro' message 'Hit the ToDo button to reformat flash' appears
      on the handheld, press the ToDo button on the front panel of the
      handheld to perform the reformat.
    Applications and databases you stored in Flash will be removed, and you will need to reinstall them.
    JackFlash Reset
    On machines that have JackFlash (a third-party enhancement that
    provides user-access to free Flash memory) it is possible that moving a
    The makers of JackFlash have provided for an additional reset procedure
    that will temporarily hide applications you have moved into your Flash
    memory.
    To do a JackFlash reset:
    1. Use the reset tip tool (or
    2. Release the reset button.
    3. Immediately AFTER step 2, press and hold down the Memo button. If you do this correctly, the Alarm will sound.
    4. Once
      the alarm sounds, release the Memo button. This should allow the Palm
      handheld to reset correctly, but the contents of Flash will not be
      visible until you run JackFlash or perform a hard reset.
    5. Run JackFlash and then move the items that were placed into Flash back into RAM.
    This procedure does not remove any data from Flash; it hides the
    contents of Flash from the handheld. You can still use JackFlash to
    access any valuable data.
    Debug Reset
    Sometimes while upgrading the Palm OS, there will be a connection
    interruption or other problem that will render your Palm completely
    unusable, due to an incomplete operating system.
    The debug reset will open up your serial port to allow an OS install utility to write a replacement OS directly to Flash.
    A debug reset should be done when OS upgrade instructions call for it.
    To do a debug reset:
    1. Press and hold the lower half of the scroll button on your handheld.
    2. Using
      handheld.
    On some models (but not all) the debug mode will be indicated by a flashing square in a corner of the screen.
My son was playing with my phone and he reseted,I don't remember my google account. And is asking to continue with a google account that was previously synced
Factory Reset Protection from android
and
Googles 72hrs lockout
the 72 hour lockout timer resets every time an attempt is made to create new password,
Google will send a new pass word email, to your Gmail. The time stamped on that email started the 72 hour lockout.
Best thing to do, kick back for 3 days, then create a new pass word. Also will have the option to creat a new gmail account.
Mar 01, 2017 | Google Cell Phones
Keyless fob lock out
Alarm System Operation & Diagnosis - Range Rovers
www.rangerovers.net/repairdetails/becm/alarm.html
(If done by the key, a press on the remote locking button is still required before .... the BeCM goes into a 10 minute lockout mode (30 minutes for 1996 and later ..... buttons at the dealership, you may need to reset the code on the fob - which is ...
How to reset the security lockout on a Saturn Vue
www.kittycatonline.com/.../How-to-reset-the-security-lockout-on-a-Satur...
Nov 30, 2014 - How to reset the security lockout on a Saturn Vue. ... Now, though, not only does the "phone start" system still fail to function, the remote start fob now fails to work as well. ... the Passlock system starts out in what I'll call "agressive" mode. ... basically disabling it: Get the original factory remote unlock key fob, ...
Jan 08, 2016 | Cars & Trucks
Android phone lockout app bypass
do a hard reset...but back up everything first
Aug 18, 2014 | Samsung Galaxy Cell Phones
I forgot my lockout password i need to know it there is a master reset code or number or some type of way to reset it to skip my password
Yes there is Master reset code for reset it from Security lock,You need to specify the Brand and It's Model,you can get the master reset code for Nokia DCT and Alcatel PHONE at here www.unlock-free.com and reset it.
Sep 22, 2011 | Cell Phones
What tod if there is system lockout
You can reset the system by turning the thermostat down and then back up in a minute or so or by turning the power to the unit totally off and then back on...
These things will reset most lockout conditions...
heatman101
Dec 10, 2010 | Goodman GDS80904BNA Open Flame Heater
Lockout code
you need to tell me what carrier you are with
May 27, 2009 | Samsung SCH-R400 Cellular Phone
System in lockout
depending on the age, you may need a circut board replacement, other then that if it has a blower on it unplug it, it will reset itself, if not you will need a circuit board
May 08, 2009 | Water Heaters
Palm Treo 650 Handheld Logo
1,327 people viewed this question
Top Palm Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
