Question about HP Computers & Internet
HP vs17e Monitor "No Input Signal"
I have an HP vs17e monitor. It's about 2 years old. I have tried everything I know to do (i.e. changing all cables, checking screensaver settings, etc.) and I still get the message "No Input Signal." The computer will come on as well as the monitor, then after about 3 minutes, the screen goes black and the message "No Input Signal" comes on and you can no longer do anything. I have switched out the monitors and that does not seem to work either. Can you help? I'm desparate! ThanksT J
SOURCE: monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Posted on Sep 13, 2008
rockitman187
  • 2559 Answers
SOURCE: hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Posted on Feb 02, 2009
venexcsd
  • 1185 Answers
SOURCE: monitor says: no signal input check video cable .
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Posted on Jun 27, 2009
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
  • 38 Answers
SOURCE: no input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
Posted on Aug 03, 2009
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
HOW to reset Compaq S2021A LCD Monitot
* Power the monitor off
* Disconnect all cabling from the bottom and/or sides of the monitor (especially the power cord)
* Press and hold the monitor power button down for 5 seconds
* Reconnect only the monitor power cord and either the #1 blue VGA or #2 white DVI (not both from one video card)
* Power the monitor on
* The PC should already be on. The monitor should auto sense the #1 blue VGA or #2 white DVI. If it does not, press the Input Select button and change to #1 VGA or #2 DVI
Jul 02, 2013 | HP Computers & Internet
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
I just got a Flatscreen, it smells pretty warm after a while when I have it on for a bit, I don't know if they overheat or not....but it gets kinda annoying. I have an hp vs17e monitor. I got this at a...
Shouldn't overheat unless there is damaged insulation. Possible dust that has gained ingress through the vents that is causing the smell when it warms up. You tried vacuuming the monitor gently through the vents?
Feb 09, 2010 | HP vs17
I'm getting a message on my HP w22 (about 2 years old) that there is no input signal. i have checked the vga cable and even tried a new one. the screen comes on when it's first turned on, and when i...
You might wanna check your HP w22 system
Try replacing your ram with a new one or any working one
if your ram is in good condition then check your motherboard if you dont know how to trouble shoot a mother the best way to go about is to use a new one or any working one compatible to your system
Jun 23, 2009 | Computers & Internet
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
HP vs17e automatic auto-adjusts randomally.
well why not try the monitor on any other computer
if it fails there,
bingo bad monitor.
easy no?
that shifting is bad. real bad,
if the problem in only on your PC.
then the Video (card or GPU chip) is bad.
you never said what you are plugged into
1981 to 2017, 10,00000 systems. made.
Mar 17, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
374 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
